Doing away with frt tank.
on
No you can't hook the lines together that would short-cut the rear tank back to itself, the only solution is to plug the lines at the fuel tank connectors. Here are the plugs I made, they are simply studs that I cut down to slip inside the connectors, a 5/16" for the supply line and 3/16" for the return. You can see where I ground down the head of the studs.. that is so the stock retaining clips can be used to keep the plug in the fuel line. This worked great and didn't leak.. I used the truck like this for over a year.
Thanks, I guess it would help if I read the tread you left. I've been in the garage trying a different route. I went to the parts store and got a fuel filter and snapped the two lines together. It was starving for fuel, so I came back in and read your post. I fill like a damn fool because I've been out there working at it now for a couple of hrs. So tomorrow I'll try it your way. Thanks
I'm confused on why you need to bypass or plug front tank....
Just don't select the tank, keep switch on back tank only. if fuel is transferring from tank to tank you have a valve failure also...
My 90 F150 has a bad front tank also and has been for couple months now, I just don't use it no issues....
Yes you could. Just cut the ends off the fuel filter you bought flush with the end of the filter. Using a double flaring tool bulge the cut end and put a FI fuel hose on the flared end. Then the other end of the hose you could stick a bolt in it. Use two FI hose clamps at each end of the FI hose.
I did something like this to my F53 to install an extra fuel pump around the in tank (pump) FDM to the engine.
I did this in case of emergency and the in tank pump quit on me on the road as it only had one 75 Gal fuel tank.
not as clean of an install as Conans talking about, but what I did was take the defective fuel pump put it in a vice and cut the metal fuel pump lines off where the fuel lines go from that top plate with the electrical plug and then into the plastic pump housing, I then removed the return line plastic fitting pushed it over the cut end of the metal fuel line and used a hose clamp on it and the other side which is the pressure line I hooked up to the corresponding nipple it originally ran to effectively looping it which for all intents and purposes makes it towhere it's essentially like it's not even there and allows the rear pump to pressurize and send fuel to the engine without pissing fuel all over the driveway. Truck ran fine this way although I'll probly make some of those bolts Conan talks about at some point.
There is no selector valve on '90+ trucks the fuel lines just have a simply tee connector at the front tank, so if you don't plug the lines it'll just dump fuel on the ground. These plugs are the easiest way to do this, took me all of 2 minutes to make these with a hack saw and grinder.
Just like to understand.
