NEED 83 Ranger 4x4 4cyl sending unit. Please help
Old 01-06-2011, 01:25 PM
hardwaycooke's Avatar
hardwaycooke
hardwaycooke is offline
Exclamation NEED 83 Ranger 4x4 4cyl sending unit. Please help
Have looked everywhere. would buy one at most any price.
thanks
Old 01-06-2011, 02:06 PM
michigan66's Avatar
michigan66
michigan66 is offline
Hi and welcome to FTE. This is a great site to get lots of good Ranger help.
What type of sending unit are you looking for - coolant temp, oil pressure, fuel tank level or what?
LMC Truck may be a good place to fing what you are looking for.
Old 01-06-2011, 04:03 PM
hardwaycooke
fuel sending unit. was told any 4 cyl would work, 2.0,2.3. hope I can find one soon.
Old 01-06-2011, 05:56 PM
Copedawg's Avatar
Copedawg
Copedawg is offline
Old 01-06-2011, 06:49 PM
hardwaycooke
i dont understand?? this is not a sending unit so what does it do??
just asking. i have no idea what the fuel sending unit looks like or how to repair it or for that matter, whats wrong with it.
thanks
Old 01-06-2011, 06:56 PM
ranger pat's Avatar
ranger pat
ranger pat is offline
Fuel sending unit, meaning the thing inside the fuel tank that makes the fuel gauge read?
or fuel sending unit, meaning the pump that sends fuel to the engine?
Old 01-06-2011, 06:58 PM
Old93junk's Avatar
Old93junk
Old93junk is offline
Your talking about the fuel gauge sender unit, right?
Old 01-06-2011, 06:59 PM
hardwaycooke
yes...my gauge inside the truck does not read.
thanks
Old 01-06-2011, 07:06 PM
Old93junk's Avatar
Old93junk
Try replacing with a Junk yard sender first, that will give you the knowledge to tackle yours by first getting one in the J-yard.
Be warned, the gages go belly up as often as the sender units......another trip to the JY.
Bad connections can be the problem too, I have seen just about all the problems these trucks can throw at you, having owned one since 84.
Old 01-06-2011, 07:10 PM
hardwaycooke
yes the thing inside the tank that makes the fuel gauge read.
thanks
Old 01-06-2011, 07:12 PM
hardwaycooke
have been/called tons of jys. noone has one that is for an 83 4cyl. is there a way to check the gauge??
Old 01-06-2011, 07:19 PM
Old93junk's Avatar
Old93junk
With a junk yard gauge R&R......Sender units are no different, 4cyl or V6 .......Some one has been making you waste your time, pull one from a v6 model if possible.
Old 01-06-2011, 07:22 PM
hardwaycooke
ok, so i can use a gauge from any size engine from only an 83 ranger, right?? or are there any other options..years, etc.
thanks
Old 01-06-2011, 07:30 PM
Old93junk's Avatar
Old93junk
83-85 just make sure tank capacity is the same. (Fuel sender unit)
Old 01-06-2011, 07:35 PM
hardwaycooke
could i possibly call you??
or you can call me 419-602-2338
i want to b positive i understand and i promise not to stalk you after.
thanks
dennis
Quick Reply: NEED 83 Ranger 4x4 4cyl sending unit. Please help
