compression ratio question
Putting together a 410 and have the 381NP pistons. Heads are stock C7. I assumed that these pistons would give my the stock compression ratio of around 10.00-10.5:1. They look and measure (except for bore) the same as the 428 pistons I just removed from a 66 428, same dish with valve reliefs. I noticed today on e-bay they have a set and advertise the CP as 8.2:1, that's a long way from 10.5:1, anyone know what the CP would be with this piston set? Thanks
Piston pin height
Deck Height
Piston volume cc
Cylinder head CC
Bore size
Rod length
Head gasket bore size
Head gasket compressed thickness
all must be accurate measurements...then we can calculate the Compression ratio ..............
Most 390 engines have pistons .050-.100 in the hole = No compression
In the 60's 390 pistons had the 1.78 or so pin height and in the 70's it went down to the 1.68 height if I'm not mistaken. This reduced the comp from 9.5 or 10:1 to 8:1. And it was accomplished by using old 410 pistons then recast as 390 truck pistons. If you try to order pistons they almost always will try to sell you the low comp version. Cant really remember what pistons got the 410 up to quench, the brain is failing at 4:30am. I'm sure a search of the forum will get you all the info you need as this topic has been covered numerous times.
The book may show that those were the original specs, but the piston manufacturers have rolled over to poor gas and the EPA and changed the specs on the pistons they now produce, even though they still claim them as "direct replacements". Also compression is also effected by combustion chamber size and head gasket thickness.
05-07-2012 08:58 AM
76f1390
21
02-11-2004 12:26 AM
67 428 Fairlane Ranchero
01-30-2003 08:12 PM
sgreen
01-26-2001 09:58 AM
