Refurbished Speedometer & Gauges
Refurbishing Gauges
I have used Bob's Speedometer Service several times, and they do concours work. Expensive, but flawless!
https://www.bobsspeedometer.com/1/120/index.asp
Regards, Mark.
Regards, Mark.
There's a couple of fellows on the Ford Barn:
jrnichols642@yahoo.com
Bill Wells bwells4608@comcast.net I've bought a refurbed speedo from Bill. Great to deal with and price was very reasonable.
They make repos.Here is one for $135.It may just need some lubrication.A lot of these speedometers have a plug you can remove for a little drop of oil.Not sure about a 56 speedo.Remove it and look at it for a lube point and run it with a drill or just hook cable back up and drive truck before going to all the trouble to completely install it back in to test!
https://www.ebay.com/i/123728025789?chn=ps
Yes, there is a little weep hole for a drop or two of light oil. With old Speedos I worked on I used WD40 liberally in the hole, on the gears until I could spin it with my thumb and forefinger. I put a Q-tip in my drill inserted into the hole were the cable goes and put the drill in reverse I could get it up to 60.
will I be able to do this while the speedo is installed or will I have to remove? I’m thinking remove.
Joe
I think 56 instrument panel can come out through the front. I know the 53 to 55 panels can. You need to back them up, then turn them and bring them out the front partway then you can remove the wires and the Speedo cable. Then there are screws in the back to remove the Speedo head. Then you can see the gears to really lube them.
They might be something holding up your needle somewhere.
On my 54 by speedometer seized up a couple years ago and I did the same thing. Lot's of WD-40 then added drops of oil. Then used a square drive in the drill to spin the speedo.
Unfortunately with factor turn signals I couldn't get the speed out through the front. It came out the back but it wasn't easy.
t_b0ne
03-20-2019 06:27 PM
ebrowder
07-29-2004 10:19 PM
ddurant
06-06-2003 02:50 PM
