Not using truck enough?
I don't use my truck much over the winter months; I try to get it out 2x a week. Is it hard on the truck to sit around say for week at a time?
I live in the frozen north of BC about 70 mile north of Seattle so this time of year day time highs are only 35-45 degrees and lows are about 26-32.
I usually use the block heater for about 2 hours before starting and let it idle for about 5 minutes before gently driving another 5 before I give her any real stress.
With a gas vehicle it was never a concern but with the 6.0l should I be driving more to save repairs down the road???
I am the same way Ben, my Ex may sit for a week. Fortunately I live 12 miles from town and when I fire the 6.0 up that is usually the shortest distance I go one way. Diesels like to run and get up to temp, I don't fire it up to move it around the drive unless I absolutely have to, my gasser SUV handles the trailer jockeying, trash hauling, short distant duties.
Guys... common here, please.
Gas or diesel... it does not matter....
Short trips and not getting one's motor up to temp to burn off any moisture that may be present in the oil or motor is crucial.
Short trips which do not fully charge one's battery is also crucial... as your alternator will not charge the battery if too many short trips are driven in a short period of time.
To let a truck sit for a 1 - 3 weeks is not an issue.... to let them idle for 15 to 30 minutes and think your charging the batteries and warming it up is harder on the motor than doing nothing or not driving the truck at all. A diesel with an EGR system does not like to be idled for long periods of time and will carbon up.
Short trips here and there is fine and will not hurt anything... but this will impact how frequantly one changes their oil due to the moisture that is built up over time (moisture and sulfur/soot makes sulfuric acid... which is not good over the long haul for your motor). This is why mechanics will always advise to change the oil in cars, trucks, boats, lawnmowers and motorcycles... prior to putting them away for the winter.
Gas or diesel... just drive your truck once a month until all temperature gauges come up to temperature and run it for awhile. Also have your climate control set to "auto" so your A/C will circulate as needed... this will also circulate the AC and the lubricant to keep all the seals in good shape.
Running your truck at temp for 20 - 30 minutes around town or on the highway will circulate everything, charge the batteries and cycle the turbo... and burn off any moisture in the oil.
The use of a quality diesel anti-gel fuel additive (even if using "winterized fuel) is recommended to maintain the cetane levels, prevent moisture and prevent gelling!!!
Lot's of good advice!
I was concerned that there were problems related to 6.0l that would be an issue from sitting to long.
I don't see anyone highlighting anything so my current practices seem to be OK.
Why own a 6.0l that I don't drive daily......I have a 10,000 5th wheel and an acreage that always needs something.
My daily driver is a Civic that gets 40mpg; what does your 6.0l get-mine get's 13-15mpg.
Save some oil for the great grandkids!!!
Excited new FE member with a 1975 F250 4x4, 4spd. How can I clean up a sun damaged instrument panel?
Wyoming1975F2504x4
01-12-2015 11:31 AM
Seattle50
32
12-18-2013 06:21 PM
BWST
06-01-2013 05:29 AM
996carl
04-24-2002 01:08 PM
