Bad idle when weather is cold 2000 f-150
I have 2000 f-150 125,000 miles. Engine idles very rough when the ambient temp is below 20 degrees. I have replaced the idle air control, both up stream 0-2 censors, 2 vac lines that come off left side of throttle body, cleaned air temp censor in air intake. when I say cleaned, i sprayed with electronic cleaner, that did help my fuel mileage. check eng light is back on, have not had a chance to see what code is now. PLEASE respond to chuck3902@insightbb.com
Don't chase it until you read the code. I chased a bad idle... lack of power when cold on the son's 2000 Sunfire with all kinds of things. It had been tossing a cat. code for a year....would come and go. Even though I know better, I ignored that and spent 100's on sensor's and my time. A friend who is a mechanic said pull the ex. pipe at the manifold and see how it runs..... Ran perfect...story short....plugged converter. Lesson learned....start with the basics.
Nathan Plemons
05-12-2015 05:15 PM
Nathan Plemons
23
06-22-2009 10:57 AM
