P0470 relation to EGR?
Could a sticky EGR valve create a P0470 Exhaust Pressure Sensor Circuit Malfunction? The EGR was replaced under warranty last summer but I don't know how well they cleaned the port. I recently had the ICP sensor and regulator replaced at the dealership and have had my emission light come on again. I can't remember what that code was but he mentioned the MAP sensor but said my turbo was fine. He cleared it out and said to see if it does it again. Of course it did so I borrowed a friends code reader and it showed this error twice. Both times it was very cold out.
I would try cleaning the EBP tube first...sometimes they get clogged up. Here's a pic of where it is on an '03:
Page 9: Component Locations
If that didn't work, I'd replace the EBP sensor.
EBP is one of the things the PCM looks at to determine EGR valve operation, but if your problem were a sticking EGR valve I think you would be showing codes to reflect that.
ZombiePopper
02-22-2015 07:29 PM
lannondiesel
1999 to 2016 Super Duty
04-10-2010 09:01 PM
