V10 swap starting monday....
im in manchester right on the bolton line its only about 12 miles to you i should be able to sneak down there. moral support/tool grabber
Nice! I'll try to be thawed out by then. I'm going to work on it this morning, I have to make dinner for family at about 5:45 so we'll see what we can have done by then; truck is outside up against garage opening so it'll be cold today
Well guys looks like the transplant is going on hold....
I started cleaning up the exhaust ports on the heads on the newer engine today and it seems I got the sticky end of the stick......
4 of the header bolts are broken off in the heads; 1 is flush and 3 have about 1/2" sticking out. The one that is flush actually had the exhaust gases eat away the aluminum of the head and I may need to reuse my old head; not sure if I need to recondition the head, it has 160k on it...
At least we can get the old one pulled today and swap out the starter, flexplate, and whatever else.....
#28
#30
