V10 Engine Oil Question
I have 2005 V10 that has 78K miles on it. I have always and only used Motorcraft 5W20 semi synthetic oil and FL820s filters. I just changed my oil and didn't realize until 6qts were in that I purchased Motocraft 5W30 semi synthetic. The owners manual doesn't recommend anything other than 5W20. Will I have any problems?
If you were south of latitude 40, I would say no issues or risks whatsoever.
But you profile says upstate NY. Brrr. Qualifier time....
If you park your truck outside with no block heater, you may want to try to avoid or at least minimize start ups on sub 0 degree days. Other than that, good to go!
Things in your favor:
Ford orignally spec'd 5W30 for V10's, and it does not appear there were any design/bearing clearance changes when the spec changed.
Your engine s/b broken in by now and not super tight.
Semi-synth will flow somewhat better than non-synth at low temps.
