Check Engine light flashing randomlly driving
Old 12-26-2010, 11:16 PM
IDIDieselJohn's Avatar
IDIDieselJohn
IDIDieselJohn is offline
'89 F150 300 Straight 6, C6, 62k miles
Been doing it for a couple days now, driving down (on the highway only) the Check Engine flashs randomlly, sometimes even looks like the bumps makes it light up, will stay on for a solid few seconds, then off, then flash again.
Seems to stay on solid whenever you really put your foot on the gas. Whenever theres a good load on the engine. Let off, light turns off, driving along @ 55mph flashes randomlly?
Could it be a loose contact/connector for something since it seems that the bumps affect it?
When I get off the highway, it's off and never comes on, not even with the bigest bump.
Old 12-26-2010, 11:30 PM
timbersteel's Avatar
timbersteel
timbersteel is offline
Have you pulled codes? Or get a friend or someone to sit in the driver seat while you wiggle the wiring.
Old 12-26-2010, 11:36 PM
IDIDieselJohn
I don't have a codes reader. Not right now anyways... never bother getting one, never had a computer controled engine before 7 months ago...
But the light is never on parked.
Old 12-26-2010, 11:53 PM
Hotshot869's Avatar
Hotshot869
Hotshot869 is offline
Mine does that, it's my EGR sensor malfunctioning. IDK if that is the problem, but it could be it! ^_^
Old 12-27-2010, 12:42 PM
Lazy K's Avatar
Lazy K
Lazy K is offline
Ford Fuel Injection » How To Run a Self-Test Here is a link to instructions for getting any trouble codes without a code reader. The CEL does not have to be on for there to be trouble codes.
Might be worth doing.
Old 12-27-2010, 04:49 PM
mikeismadness's Avatar
mikeismadness
mikeismadness is offline
my 95 bronco did the same thing going down the highway...inbewteen 55-65 the check engine light would come on until i slowed to about 45...do the self testvery easy to do...but in the test i found it easier to not do the slash marks...whatever works best for you though
Old 12-27-2010, 05:15 PM
cadillacmob's Avatar
cadillacmob
cadillacmob is offline
My stang was doin that, was idle air control sensor . Best thing to do is self test like lazy k said
Kris with a K
1999 to 2016 Super Duty
02-24-2017 03:09 PM
mcinco2000
10-15-2015 07:58 AM
12valveEx
08-16-2013 08:24 PM
Coalroller
01-02-2010 09:45 AM
akidagin
12-10-2007 01:00 PM
Quick Reply: Check Engine light flashing randomlly driving
