traction bars for 96 250/350
#46
Clearance shouldn't be an issue. It just depends where you mount it on the axle. My setup doesn't drop below the bottom of my diff so it wont limit clearance
#47
Thanks for the reply Ryan. I checked out your pictures in your gallery and your setup looks clean and professional.
Is you bottom mount just a piece of flat iron that goes through the U-bolts undernearth of the block spacer?
What about the top mount? You have it on outside of the frame right?
#48
The upper is made of 1/4" 3x6 angle with 3/8"x4 flat bar and is mounted to the outside of the frame.
Thanks for the comment, I put a lot of time in trying to make it look nice
#50
#51
i undersand how it will stop from bind, but now arent the ladder bars usless because now the ladder bar can move freely with the axle back an forth?? it will stop it from twisting, but what about hopping????
#52
Yes, a ladder bar set up with a shackle front mount will move back and forth as the suspension flexes like it is supposed to. (as can be seen in my attached video) That is normal.
In order for the pinion angle to climb, like in a wheel hop or axle wrap condition it needs to push up in a near vertical plane on the shackle, which it will be unable to do.
Btw, a traction bar, not ladder bar, needs to be mounted below the axle tubes, not above. The bar will have much better leverage to control wheel hop mounted below than above.
<iframe width="420" height="315" src="https://www.youtube.com/embed/cYnJX1WIYUE" frameborder="0" allowfullscreen></iframe>
SoCalAngler
22
05-11-2021 02:21 PM
jg96powerstroker
04-26-2018 05:37 AM
macrobatic
03-07-2017 01:16 PM
