Door speaker wiring +/-
I swapped my stock speakers for a pair of Infinity separates (tweeters mounted on door frame). The color code for the factory speakers was pretty much undeciferable so what I did is just hook them up and listen to an AM station (mono). If it sounded like one point source in the middle of the dash, it was connected properly (in phase). If you move your head between the speakers and it sounds funny, the speakers are out of phase. Just reverse one pair of wires and you should be good to go.
Radio Ground black and black/lt. green - radio harness
Radio Ignition pink + radio harness
Radio Illumination lt. blue/red (dimmer) + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- orange/lt. grn - lt. blue/wht +,- radio harness
RF Speaker +/- white/lt. grn - dk. green/org +,- radio harness
LR Speaker +/- gray/lt. blue - tan/yellow +,- radio harness
RR Speaker +/- orange/red - brown/pink +,- radio harness
Power Antenna N/A
Power Antenna N/A
Power Antenna N/A
Thanks, i ended up playing with the wires to see which setup sounded best. I had a wiring diagram from Ford from when i installed the head unit but couldnt find it.
rodp14
08-03-2017 04:53 AM
f100today
07-19-2016 09:22 PM
Ace!
09-27-2008 02:23 PM
