2011 F150 Ecoboost rated 15 -21 MPG
I agree, no way to prove that this is an authentic factory window sticker. But if you read the entire sticker, you'll note the 3.55.1 axles. Likewise, under the EPA estimates, you'll also notice that average MPG's is rated at 17. While the it says 15 city and 21 hwy, you'll also notice that city says 12-18 and hwy says 18-25.
I have seen a sticker for a 2011 F-150 4x4 Screw 5.0L with 3.73.1 axles and it was rated at 14 and 19 respectively. I would expect the 5.0L to regularly get 20.
For the 5.0 in a 4x4 SCAB standard axle is 3.55. For a 4x4 ecoboost SCAB standard axle is 3.31. If Ford does the epa tests with the SCAB these are the axles that they use- they do not test each axle. Haven't you ever noticed that their are always only two EPA figures for each engine? One for 4x2 and one for 4x4? That is because they test only one axle for each. Look at the 2010 5.4. They only had two ratings 14/20 for 2wd and 14/18 for 4x4 and they had a lot more axles than that.
They are not even required to say whether they tested with regular cab, SCAB or SCREW. So they could do all tests with the regular cab, save about 500 lbs of weight and skew the figures up another mpg or so.
Not speculation. There was a thread on here with a link to a test with the 6.2L and EB towing 6K lb. and the EB came in at 9 mpg or there abouts and the 6.2L came in at a little over 10 mpg. The EB is just short on displacement to deliver good fuel economy towing. But a good programmer could change that like it has with diesels.
The only reference that I know of to the ecoboost while towing fuel economy, came from a guy over on PUTC that went to the BBQ dinner and ecoboost unveiling before the state fair. One of the questions on the list of questions that we asked to be answered was, what kind of mileage did it get while towing? The engineer's answer was "within 1 mpg of a V8" but he didn't specify whether up or down!
Either way, 1 mpg isn't a killer. Besides the ecoboost will do so much better unloaded than the 6.2 that you will come out way ahead. Honestly if I was towing everyday I wouldn't buy the ecoboost anyway, but I will not be afraid to load it to the max with cows or hay, cause that's what it was designed and tested for.
Depends on how much you want to tow, the 3.7 is limited to around 6k max, the 5.0 is 10k max. So you lose 2 mpg but gain 4000 lbs in capability. If you drive 15k miles a year it probably wouldn't cost you more than a couple hundred extra a year for gas (I didn't calculate it just guessed)
#30
