clutch on a 94 Ranger
Old 12-22-2010, 11:28 PM
danielwd's Avatar
danielwd
danielwd is offline
94 Ranger, 170,000 miles, 2.3 L
I replaced my clutch, pressure plate, slave cylinder, and had my flywheel resurfaced. I bled my slave cylinder twice following Haynes instructions, and I'm still having problems which I don't even think stem from my new clutch.
I cannot shift gears at all, with the truck NOT running, or with the truck running. I have inspected the throw out bearing push against the pressure plate from underneath the truck through the inspection port under the bell housing, and I can see it move against the pressure plate.
But what really makes me curious is the fact that even when the truck is not running at all, I cannot shift out of neutral into any gear with or without pushing the clutch pedal down. This issue should not be connected to the clutch at all because the truck is not even on and I'm not even engaging or disengaging the clutch. It makes me feel as though there is now something wrong with my transmission, but it was fine before.
Here's another kicker! After I start the truck, if I take my foot off the clutch pedal, the truck stalls!
Any suggestions...thanks in advance.
Old 12-23-2010, 02:36 PM
Lazy K's Avatar
Lazy K
Lazy K is offline
My guess would be that somehow the transmission input shaft (mainshaft) is jammed hard against the flywheel. Either due to a wrong pilot bearing or wrong/distorted clutch plate.
If it was me I would pull the transmission again and have a look.
Old 12-24-2010, 10:23 AM
stuart1's Avatar
stuart1
stuart1 is offline
I answered in a different fourm and this has been corrected.
The stick was not aligned with the shift rails.
stephano
1983 - 2012 Ranger & B-Series
05-21-2011 11:17 PM
danielwd
21
12-27-2010 05:47 PM
fordopie
09-02-2009 05:56 AM
glenn65
16
12-31-2005 12:16 AM
Gov
10-30-2004 09:45 PM
Quick Reply: clutch on a 94 Ranger
