2006 Expedition XLT 60K Service - Ripoff?
Dealer wants $1,060 for the service. We bought it used 4 months ago and it went in for a new battery.
Dealer wants to perform the following:
Oil Change/Filter
New Serp belt
Fuel service (injector cleaning, top engine decarb etc)
Fuel filter
Brake fluid flush
Air filter
Power steering flush
Transfer case flush
Rear differential check bearings, rings, pinions, new gasket and fluid
We have a used vehicle warranty which says we must abide by the servicing requirements as found in the vehicle manual. This says:
❑ Multi-point inspection (recommended)
My question is, for this vehicle, what do we NEED and is there anything else that is recommended above the essentials? We never go offroading.
Oil Change/Filter
New Serp belt
Fuel filter
Brake fluid flush
Air filter
Transfer case flush
Change engine oil and replace oil filter.
Inspect tires for wear and rotate.
Inspect brake pads/shoes/rotors/drums, brake
lines & hoses, and parking brake system.
Inspect wheel ends for endplay and noise.
Inspect engine cooling system and hoses.
Inspect exhaust system and heat shields.
Inspect steering linkage, ball joints, suspension
and, if equipped, half shafts, driveshaft and
U-joints.
U-joints.
Replace engine air filter.
Replace fuel filter (see page 47).
Replace cabin air filter, if equipped.
Change automatic transmission fluid on vehicles
equipped with the Torqshift transmission. Replace
the remote filter element on the vehicles
equipped with the Torqshift transmission. Inspect
automatic transmission/transaxle fluid level
on all other vehicles, if equipped with dipstick.
Consult your dealer for your particular
requirements.
requirements.
Replace climate-controlled seat filters if equipped
(Navigator and Expedition).
Lubricate ball joints and steering linkage if
equipped with zerk fittings.
Lubricate 4X2 front wheel bearings, replace
grease seals, and adjust bearings (if not
equipped with sealed bearings).
Change manual transmission fluid.
Inspect and lubricate 4X4 front axle shaft U-joints
(F250/350/450/550).
(F250/350/450/550).
dealer ripoff
I would change all fluids and filters, including the transmission fluid and filter. Skip the fuel injector cleaning (not on their list anyway) and add a bottle of fuel injector cleaner to your gas tank at the next fill up. As far as cost, I wouldn't know, since I do all of this myself because i dont like getting ripped off. Also, when i do it myself, i know it got done. Probably get a better price at an independent shop. Good luck.
What he said, saying that however when I bought my 2001 a couple of years ago with 59,000 miles, went in for minor service and dealer talked me into most of that, around 800 dollars. Didn't have the transfer case flushed or the belt replaced for example. I kind of thought one time, why not at least I know what's been done to the truck at that point - was it a waste probably - but I knew I wanted the coolant and trans fluid flushed anyway, so I was half way there. Two years later chasing a rough idle, I had to do the plugs anyway with the COPs (Coil over plug) and that was the real idle issue anyway.
In the old days to clean the injection system you removed the air cleaner and shot one or two cans of carburator cleaner into the - carburator - while it was running and you were done - what maybe 5 dollars and about 15 minutes of time as you replaced the air filter anyway.
If they break down the estimate you may be shocked to see what they are charging for the belt and labor to put it on, same with the air cleaner. In some lame defense of what they do charge, if you pay the guys in the garage good money, some do get paid good, and by bad luck their day is spent doing the above - but with special tools and adaptors, well when you are done covering overhead and making money, you charge high prices (Remember the movie Used Cars and what Marshall Lucky did to high prices.) and people don't come back.
Did I digress enough, but I hope I gave you some ideas on what to look for.
Mike
Mike
1060 seems kind of steep for what you have listed even at a dealer. Did you get a breakdown of what each item costs? Of the ones you list I would do these:
oil change
fuel filter
air filter if needed
brake fluid flush(brake fluid collects moisture and moisture is bad for brake parts)
transfer case
transmission flush if the fluid is dark
The rest are not necessary.
oil change
fuel filter
transfer case
Thanks for the advice. Spoken to a local workshop and they reckon out here (Utah @ 4,700 feet) there isn't enough moisture in the air to warrant a brake fluid change until 100K miles. Gonna make a few more calls and get some better prices. There ain't no way I'm paying 1K+ for a service. I've had major services on a BMW cost less.
Dealer wants to perform the following: If you do the following, these prices are pretty accurate across the board.
Oil Change/Filter $20 max
New Serp belt $50
Fuel service (injector cleaning, top engine decarb etc) 1 or 2 cans of Seafoam $8 ea
Fuel filter $10
Brake fluid flush 3 qts of fluid $21
Air filter $13
Power steering flush not needed, but if you insist, $5 qt
Transfer case flush not sure, haven't owned a 4X in years
Transmission flush $75 for 15 qts
Rear differential check bearings, rings, pinions, new gasket and fluid I wouldn't let just anyone touch my rear end , gear oil $6 qt X your capacity (maybe 5 or 6 qts?), $5 gasket
New Serp belt $50
Fuel filter $10
Air filter $13
Valvoline 80W-90 in 1 ga container is about $16 and is good for conventional and limited slip. Lucas synthetic is about $15 a quart. Do these require synthetic?
Got it! Just read my manual and it says synthetic ONLY, but it also says it's "considered lubricated for life, not to be checked or changed unless a leak is suspected, service is required, or unless it's been submerged in water". From what I read, we leave the diff alone unless there's a problem.
Depends on what it was ordered with, it is an option. There is an axle code on your door jamb sticker which will tell you.
Here are the codes from another thread...
17 is 3:31 non-limited slip
H9 is 3:55 limited slip
H7 is 3:31 limited slip
H6 is 3:73 limited slip
