Motorweek- Pat Goss & Spark Plug Removal Technique Different from TSB- Much Different
Holding a spark plug from a Ford 5.4 (late model), he stated his shop uses the following procedure:
1. Remove COPS
2. Loosen the spark plugs 1/8 of a turn max
3. Reinstall COPS
4. Start engine and shut off immediately
5. Remove COPS & plugs
His theory.....
by loosening the plugs then firing the engine, this burns the carbon off the end of the plugs that can get on the threads and of course cause the broken plug.
Ok, Since I can't picture in my mind how this would work, unless by loosening the plugs a tad allows the "fire" to travel up, burning off the carbon.
Ok techs- your thoughts? has anybody heard of this?
1. Remove COPS
3. Reinstall COPS
His theory.....
These threads do not get any carbon on them. The threads have nothing to do with the breakage. The threads are above the seal. The traditional sparkplug design has the seal above the threads so those threads do build-up with carbon.
I haven't seen the theory but my guess is: by opening the seal and starting the engine, the high temperature combustion gases now have a path to flow past the shield, past the seal, past the threads, and to the outside. The high temperature gases should burn the carbon off.
With the plug tightened, the seal stops flow so that region does not get hot enough to burn the carbon off so it collects.
here's a link
MotorWeek: Auto Basics: Goss' Garage
His discussion of the threads is incorrect - I wonder if he does not know that his explanation is wrong, or if he is simply taking some "liberty" in his explanation.
It doesn't hurt to start the engine as it may help to blow away some of the fractured carbon buildup but I would not trust it completely. I suggest adding solvent if the removal torque goes above 25 ft-lbs. And work it back and forth as he suggests. Some where on this site it has been measured that the ground shield will break off at about 32 ft-lbs. You likely will need to exceed this torque when doing the "no more than 1/8 turn" loosening since the installation torque is close to 32 ft-lbs but do not exceed after that.
here's a link
vze2sgxa
Modular V8 (4.6L, 5.4L)
20
08-08-2008 06:32 PM
