1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Yep, another leaf spring question thread...
Old 02-24-2011, 08:52 PM
alstaregixxer's Avatar
alstaregixxer
alstaregixxer is offline
I've searched here, plowsite.com, powerstroke.org, and several other F-series enthusiast site with no clear answer to my question.
Are there more than one X code spring? For example; Is there an x code for 5.4 equipped trucks and on for v-10, diesel truck, or is it a one size fits all deal?
I just bought a set of X codes from a 5.4 truck, and want to install them in my diesel. My thinking is that there is only one x code, and it fits all applications. Correct?
Old 02-24-2011, 09:02 PM
bigblue61's Avatar
bigblue61
bigblue61 is offline
Only one, you are correct
Old 02-24-2011, 09:06 PM
alstaregixxer
Thanks, just wanted a 2nd opinion before i tear into it.
Old 02-24-2011, 10:03 PM
bigblue61's Avatar
bigblue61
ha good luck and post some pics, I'm thinking about making the swap
Old 02-24-2011, 10:42 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
They will work great..
Old 02-25-2011, 12:16 AM
78bigbronco's Avatar
78bigbronco
78bigbronco is offline
I've always been a bit foggy on the whole 'X-code' thing. What exactly are they? If X-code designates the highest # springs available (6,000#) then according to the datasheets they were not available on all models. For example the snow plow prep package would have the 6000# rating on a CC LB 5.4 but drop to a SC or SB and the snow plow prep is 5600#. So I'm not 100% sure what the X code designates. I am sure this has been explained before but I may have missed it, in which case I'd appreciate being brought up to speed
Old 02-25-2011, 02:24 AM
bigblue61's Avatar
bigblue61
Your right on they are the highest rated springs available for 99-04 super duty trucks, they came standard on 450-550s and are on some plow preps
Heres my GUESS about some of the differences you mentioned
CC have more weight over the front axle because they are heavier than reg cabs and ex cabs (obviously) therefore requiring a higher spring capacity, hence the x codes. So for an reg/ext cab less spring is required which results in an improved ride. The CC weighs more needs a higher spring rating.
Old 02-25-2011, 03:09 AM
78bigbronco
Yes I understand the differing weights of the truck need different springs which is why there are so many and based on truck config. My point is that my assumption is the "X-Code" means 6000# rating (the highest) and please correct if I am wrong. According to my 2009 specs (which could be different, IDK) the ONLY config that a 5.4L truck would have the 6000# springs is a CC LB w/snow plow pkg. Not unheard of but rare, unless the previous owner had them put in.
alstaregixxer - are you certain they are really x code springs?
