What are water pump failure symptoms?
#46
Well Ford says it's not the heater core. Of course after they install a new one for $400. THen they tested for combustion gases. I suggested they not replace the core and just shut it off (crewcab). THey said it is better to test knowing the heater core works. Fine I'm no diesel tech.
Combustion gases in coolant. THey say head gaskets. THey said they would get working on it asap. I said "Give me my keys". He said "Don't you want it fixed?" I said not by them. I'm taking it to the guy that did my tranny. He's gonna pull the motor out and inspect everything. He's thinking that the heads and block may just need to be decked properly. Worse case I'll be looking at a new long or short block motor. He said it's possible to go with a forged long block too.
Any advantages to a forged block? Or is standard good enough?
I'm gonna still run the same mods. 190's and the Powermax with Eric's Extreme street. I'm guessing at least 500 HP or more.
Any tips on good long block makers?
PS - The tech said they wouldn't refund any money from the 2nd head gasket job. He said I am running lots of HP. I said it's not any worse then the Edge Attitude they suggest and installed for me 5 years ago lol. (head gaskets blew and tranny was ruined within a year) He said his own personal 6.0L has had the head gaskets blow twice. He had them fixed at that shop. I asked, Did you deck your heads? He said no. Lesson learned. Anyone needing a head gasket job should insist on having them checked by a machine shop, not just the Ford tech. procedure!
As far as the head checking procedure it's allllll about having the correct tools. It's NOT that hard to measure a head. The spec, IIRC, is <.004 measured across the WIDTH of the head, not the length of the head. IMHO that's still way too much for a good seal.
#48
Also, the crew cab trucks have a shut off valve on the "supply" line to the heater core. Is is possible that the valve isn't getting a good vacuum and thus closing from time to time? The tube and "boot" are far from bullet proof...so they could be the issue with your loose of heat in the cab. I'm with Tim, demand to talk to the GM of the dealership. It worked well for me when I had mine at my local dealership last summer...we have a much better relationship when I'm there these days.
400 '77 F150 Ranger
05-11-2017 03:37 PM
muddinbronco87
02-06-2016 11:17 PM
fsvahn
02-26-2012 08:10 PM
rjdavis21
20
07-28-2009 08:40 AM
