For those of you who have disassembled your bed, what are you going to use to attach the bedsides to the front bed panel? I see that from the factory it used a sort of pinch weld/rivet setup. Will you use the same setup or go with stainless hardware to dress it up more? Also, my fron bed panel has a welded bead running along the very top and down the slope of the front end to help hold it together. I'm guessing that was not what the factory did, but possibly a previous owner? Is anyone else's like that? If it was a previous owners attempt to strengthen the top corners, they did a pretty nice job.
I MIG welded mine - I drilled appropriate size holes in the front panel lip, plug welded them and then ground the top back smooth. I don't personally like seeing extra bolts etc in this area, but should you ever want to take it all apart again it would be a lot easier with bolts/hardware
I have the Mar-K bed front and sides. I also got thier stainless bolt kit for the bed assembly and thats what I'll be using for the same reason dawolverine mentioned. And I'll be looking for polished stainless button heads for the fenders too. Regards.
