Code 173 and rough idle stalling
I purchased one of these recently:
AC/DC Digital Multimeter
It has a frequency function as well as the usual DVM features. My old Fluke 87 was almost unreadable.
Your also going to have to test the map sensor if the ACT and ECT prove to be within spec. Test with engine cold and then when up to running temp.
Those will be easier to test, a meter with a tach function will be needed to test the MAP sensor.
However you can and should use a volt meter to verify 5v reference voltage is present to all three to start with. (Gray-Red wire)
I assume a DVM but...
Well i got the truck to idle steady and not lope as bad. I cleaned my original iac but i think it was stuck because i put one from a different intake on it that came out of another truck that ran great and that helped it a lot.
I am still having trouble with the hard start. The timing is set at 9* BTC and will not tolerate any more timing than that with out detonation. It seems to fire up fine when sitting over night, but once it warms up it is hard to start...
How do i test these sensors with the DVM?
I use the values and info from here: Ford Fuel Injection
For most of the sensors I use the output signal values whenever possible. Back probe the wires with the Key On/Engine Off whenever possible.
The hard start/pinging issue is leading me to believe that the outer ring on your harmonic balancer may have slipped. Your timing settings may now be compromised.
Yea I'd tend to agree with rla2005, sounds like your wheel slipped. Easy way to tell, pull #1 plug, get it up on TDC on the compression stoke, verify you have it exact. See if the mark is a TDC on the wheel.
When you say The timing is set at 9* BTC and will not tolerate any more timing than that with out detonation. It seems to fire up fine when sitting over night, but once it warms up it is hard to start...
Hard to start as in cranks over hard, turns a few degrees then abruptly stops...turns stops...turns stops....turns stops? If so yea either your wheel spun on itself or a computer issue of some kind more likely your wheel spun some. Your timing is to far advanced even at 9deg on the wheel as set. Back it off a couple three deg from there and see if that helps it fire when warm but still has power on the road.
ACT, ECT, MAP and TPS to cover all the bases. You also need to figure out the root cause of the pinging when the timing is set at or below recommended settings. I think you have numerous items working against you right now. Those sensors are easy enough to check out. Once you have a handle on that, maybe the pinging problem will be resolved as well.
I know when my other plow truck was too far advanced the thing sounded like it had a dead battery when i tried to start it again when it was warm. This is not like that incident though... its just hard to fire when warm
No... when it is warm, it will turn over like it should, but it will not fire right away. you have to push the gas down while turning it over to get it to start.
Testing them all you should narrow down the cause of the problem fairly quick/easy, be sure and test them when the motor is cold and then again once its fully up to running temp.
Did you replace the ACT and ECT sensors, stated you intended too back a few posts?
Reset, clear the computer after doing so?
#28
Ok yea even that points them 4 sensors, one or more of them is off. The computer is not getting the correct information and it thinks the motor is cold when its hot / below sea level but is at sea level etc etc.
I will post back to let you all know what i find.
#29
I'm at a loss with this one...
#30
If you have speed density, you will have to have a stock motor(especially a stock cam), otherwise you will have to covert to MAF, which requires a later model computer, change wires around in the harness, and MAF sensor of course. Otherwise you are just wizzin' in the wind. Super tune, chips, etc, results are very limited for speed density systems, and if you have the E4OD transmission it makes it a little harder to convert, because the tranny is controlled by the computer.
