clutch slave cylinder
appears my clutch slave cylinder is done. no clutch, fluid leaking from bottom of bell housing. still fluid in reservior, however.
can it be replaced without dropping transmission?
truck is 99 SD 2 wd, 5 speed manual,5.4l with only 120k on it. no problems with clutch before i.e. noise, slipping etc.
clutch slave
It's actually really simple. Like the other post said, it's mounted on the driver side externally. Just make sure when you install the new one you don't cut the retaining strap. It's designed to be installed with the strap. The strap will break after it is installed and you use it. Mine did the same thing this summer..... I was pulling a 27 ft pontoon to the lake! Luckily there was a napa in a small town about 5 miles up the road. 75$ and about 45 minutes later I was back on the road,and 30 mins after that I was backing down the ramp!
agui0106
06-10-2012 10:34 AM
greek4x4
New Member Introductions
11-23-2007 10:17 PM
jowilker
06-18-2002 08:10 PM
