2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Starting problems...
Old 12-11-2010, 06:59 AM
JetFuelBurner's Avatar
JetFuelBurner
JetFuelBurner is offline
2010 Expedition EL, 38k miles.
The wife experienced some stumbling of the engine pulling out of our subdivision. Intermittent. I put in some super unleaded and fuel injector cleaner. Did a road trip from GA up to IN and didn't give it another thought.
Well, last week she's coming home from work and tries to start the truck. It runs for a second and dies. Subsequent starts, it tries to start but does not get going. I have her on the phone and tell her to work the gas pedal and floor it when it begins to run. It clears up after about a minute and runs fine.
I experienced this once or twice in my 2000 F250 once or twice but once running, it didn't do it again for a year or two.
Her Exp. has done this repeatedly for a week (i've been out of town). I am putting in the super concentrated fuel injector cleaner and a full tank of high test again and going to the auto parts dealer to put the reader on it.
There were no check engine lights or messages of any kind.
EGR valve or 02 sensor? That's my first guess but I would have expected some kind of error code or check engine light...
Thoughts???
Old 12-11-2010, 08:09 AM
gddyup's Avatar
gddyup
gddyup is offline
If it were EGR related or O2 related, I would expect a code especially in a no start condition. If it were me having this issue, I would probably pull codes oike you referred to and if there was nothing there I would then most likely throw a fuel filter at it. A fuel filter would be short money.
Old 12-11-2010, 08:56 AM
JetFuelBurner
Originally Posted by gddyup
...I would probably pull codes oike you referred to and if there was nothing there I would then most likely throw a fuel filter at it. A fuel filter would be short money.
Exactly what I was thinking. No codes. Started right up for me this am (go figure!). I'll put a new fuel filter in it and see what happens.
Old 12-12-2010, 08:57 PM
BigMick's Avatar
BigMick
BigMick is offline
I had the same type of problem using gas from a" knock off" station. Filter clogged at about 25k.
Mike
Old 12-13-2010, 10:38 AM
berry1234's Avatar
berry1234
berry1234 is offline
I would change filter, and remove battery cable for 20 minutes then try that. I would stop using fuel system cleaner for the time being.
Old 01-05-2011, 04:13 PM
JetFuelBurner
Dealer did a computer reset that appeared to cure the problem. About 2 weeks later it did it again. Typically does it when the fuel is below 1/2 tank.
Picking up a new filter tonight. We'll see if I can do this without breaking the infamous little blue clips!
RANGER589
Electrical Systems/Wiring
06-25-2014 09:09 AM
RANGER589
42
05-19-2011 12:08 PM
MRSMOGSTACK
42
02-11-2011 12:52 PM
Bulldog2002
05-21-2002 04:43 PM
Quick Reply: Starting problems...
