Ford Heater Valve Warning/Fix (with pics)
Fellas,
Ok,
I started this in another thread kinda by accident. You can refer to this thread for a little back ground info, https://www.ford-trucks.com/forums/1...th-pics-7.html
In an effort to keep our information on the forum organized I am starting a new thread now...I should've done it in the first place.
Anyway, in summary here is my issue and conclusion:
I noticed my coolant level was low on my degas bottle. After inspecting everything I noticed coolant leaking around my heater control valve (thanks Bpounds). Refer to these pics Ford Truck Enthusiasts Forums - Jayybird's Album: Coolant Leak
Now I am shopping for my replacement part. Here is what I've found,
1. Called up the local dealer and it was about $76
2. ZMANN pointed out ths same part at http://www.dieselsite.com/index.asp?...ROD&ProdID=473 for $47
3. Beachbumcook also suggested checking here (thanks ZMANN for the link), http://www.fordpartswebsite.com/ .
I looked on this website I think I have identified the part, but I am not real sure. Is this it? http://www.partswebsite.com/fordpart...108&type=parts
Thanks fellas for all the help!
Ok,
Hey Jaybird,
You found my leak for me. Just wanted to post and say thanks again. I looked at that valve tonight when I was switching out my downpipe and saw a definate leak from around the top screw in that valve.
I have been loosing a small amount of coolant for months and have been wondering where it's been going, I didn't even think about that valve until you mentioned it.
Thanks again
Jeremy
Thanks again
Jeremy
2005 F250 XLT
When is that valve supposed to operate? I was looking at it last week and adjusted the heat - no change. Turned on the AC - no change. The piston is always in the fully extended position.
The heater seems to work normally. The vacuum line is connected. What operates the valve?
Yes it does. It actually T's into the air intake door control line. The air intake door is normally open, allowing air to come in from the outside. When the control is in the OFF or MAX A/C positions, vacuum is applied to air intake door control motor, closing it. This prevents air from coming in from the outside. This causes recirculated air with the fan on in MAX A/C, and no air (because there is no fan running) in the OFF position.
I just re-read your post and you said that the valve only operates in the Max AC or Off position. I don't think that I tried either of those positions on the heater. Maybe I don't have a problem, I'll check tonight.
Went out at lunch time and it is closing on Max AC and Off. Thanks for your help.
I believe this is the part number (partsguyed.com)
<table border="0" cellpadding="3" cellspacing="0" width="100%"><tbody><tr><td class="tabletext" valign="top">3C7Z18495AB MSRP 25.70 Price 15.42
VLV ASY_HTR WTR CONT
</td> <td class="tabletext" align="right" valign="top">
</td><td class="tabletext" align="right" valign="top">
</td></tr><tr><td class="tabletext" colspan="3">
</td></tr></tbody></table>Here is another link
Heater Valve - Auto Parts Warehouse
This is the vacuum operated valve at Auto Parts.
4-Seasons Heater Valve Part Number: FS74865 Manufacturer Number: 74865
- List Price: $80.64
- You Save: $12.30
- Shipping: FREE
- Our Price: $68.34
- Low price guarantee
- <HR class=dvdr><FORM style="DISPLAY: inline; FLOAT: right; MARGIN-BOTTOM: 5px" action=http://www.autopartswarehouse.com/additem/ method=post sizset="53" sizcache="14">Qty: <INPUT class=spl-qty value=1 name=qty>
<INPUT type=hidden value=Endeca.226827 name=p_id> <INPUT type=hidden value=e name=catalog_type> <INPUT class=add-to-cart-big onclick="javascript:setAnalyticsPassThroughCookie( 'Product Results', '3');" type=submit value="Submit Query" name=add-to-cart> In Stock </FORM>
- Warranty: 120-day 4-Seasons limited warranty
- 2005: XLT; All Engines;
4-mos late, but I wanted to share that I too just discovered that my Heater Control Valve is leaking coolant.
Thought it was the dreaded head gasket at first, but continued to follow the trail and it led me right to a very wet control valve.
Wonder why these things area failing? Anyway, I have the 3C7Z-18495-AB (Motorcraft #YG389) replacement on the way from RockAuto ... cost was $14.25.
