Ford f350 rear blocks on a f250?
I own a 2010 ford f250 4x4 sc with the 5.4 and the plow prep package.The truck sits higher in the front then the rear how do i level the truck?Will f350 rear blocks level my truck and what parts do i need to order to change the rear blocks thanks for any help.
My air bags seem to have fixed that problem with my 06 even with only minimal psi. But I haul a lot so I need the actual extra leveling capacity the bags provide. If you don't need that then it seems many do that block swap. Who knows maybe I'll swap too someday. Also the downside of air bags is a rougher ride.
Mine even has the overload spring and it still squatted, but anything will with a load in the bed. I just hated riding nose high with a loaded trailer attached. Now I can keep the truck and trailer level. Its funny to think that the springs are the same just the block is different to allow more squatting under load.
Depending on your rear springs, the blocks will raise your rear end up too much. You may have to address the front as well. On my '01, I ended up with tall F350 blocks, 6k front springs and a modified 2.5" leveling kit to retain a slight rake. X springs alone were not enough bring the front end up to match my rear spring rate with them blocks. Now with 285's I'm maxed out as far as I can go in height to fit my Western plow properly. Any higher and I would have had to drop the plow's ultramount brackets. Spent a lot of time working on it, getting it right, but it was worth it.
fordtrucklife92
General Diesel Discussion
03-18-2016 12:20 PM
