Engine Compartment Detailing 101
#46
[QUOTE=HIO Silver;14205784]Ya really ought to use a paint specifically formulated for engines and heat which are more resistant to oils and such.
I agree. The paint i used in the first place was specific engine paint. I actually think they had a dark one to but i opted for the light blue. I was already at walmart so i figured id take a look. I will have to check again at advance. They put it on special every once in a while for $5.99. I think ill just redo with the same color
#49
2x... I prefer a near stock look with a few details. In general, try to stick to four colors in balance. Every once in a while another color will sneak in (like the boots on my spark plug wires) but overall it's satin black, silver, a Ford blue, and, at least in my case, grey. In the end, strive for visual balance.... that's my recommendation.
I don't understand why some will paint a brake booster blue. That, among other things, drives me nuts. I mean, does one really want to draw attention to a lame brake booster? Not me. The engine is the focal and should be treated as such. Another fail are colored wiring loops that result in looking like a bunch of snakes doing the nasty under the hood. Again, distracting and gaudy.
I leave the underhood chrome and polished billet to the lawn chair racers (show cars/trucks).
#51
I ordered a bunch of Rustoleum engine paints from Summit and tried their semi-gloss/satin engine paint for the inners and firewall... in fact, almost everything in the engine compartment is from Rustoleum's automotive line except the booster. It's cast grey from a GM-oriented seller at a swap meet... it was low-buck.
#53
#54
Just to add some more thought to this post; I agree the engine is the focus point; and should stand out among inner fenders; I even paint the trans dipstick (Kelly Green) and the oil / p/s dipstick ususally a sliver or aluminum. not to hip on the yellow dipstick of modern rides. Just for thought...
#55
I don't really get how there are guidelines for engine detailing on these trucks. Personally, I am a huge fan of black and chrome in the bay and would never paint my engine parts blue or any of the multi colors that are so commonly recommended for the Ford engine bay. It would seem that the correct colors are up to the vehicle owner.
Isn't it all about personal preference anyway?
#56
How do you go about cleaning and prep for the detailing. I watched
on youtube the car engine was pressure washed and sprayed with a decreaser of some sort. (long video but first part is about the engine compartment)
I have used Gunk and covered all electric parts with aluminum foil. After cleaning the car's engine would not start. Some water got into the spark plug cables. Later I learned that WD 40 works to remove water and mositure. But how did this guy on the video get away with not covering anything is a mystry. Any thoughts on cleaning the engine?
#57
Here are the principles applied and using Rustoleum High Heat engine paint. IMO, my paint is a touch too dark. Oh well, it's what I bought... that's why I went with silver valve covers to lighten it up.:
Now that is a tidy looking engine assembly. Nicely done!
Last edited by Westcoast Highboy; 08-23-2014 at 02:41 PM. Reason: turned off email notification
#58
https://www.ford-trucks.com/forums/1...cab-frame.html
post #166/178
He painted inner fenderwells with "rustoleum industrial aluminum". And I like the silver and black and alum color scheme, the blue wire wrap....maybe.
This guy has worked his tail off on his truck and all the hard way. Ck out his cab swap method by hand and timbers.
post #166/178
EndorphinJunky
Ford Truck Parts for Sale
26
01-12-2017 01:58 PM
Brian Goodman
19
06-01-2016 12:23 PM
101ford, 1979, 1984, 56, carburetor, comparment, compartment, detailing, engine, f100, f250, ford, forum, refinishing, truck
