351w torque build opinions please
I'm debating between a 351w and a 300i6 for my truck. If I go Windsor what kind of torque can I achieve low in the power band? like 2000 rpm. I'm talking fully rebuilt roller motor with
Performer rpm intake, 650 carb, Long tube headers, rv cam, aftermarket heads, ect. Im wanting a daily driver engine that runs on 87 octane and gets decent mpg. Is 18mpg highway doable? How much torque can I get? Id love 250-300hp as well.
Opinions please!
Opinions please!
The gt40 heads are a great low rpm head. You'll get the desired torque down low, but you'll use up the capacity of them early on.
If you had the money aluminum heads will benefit you because of the heat dissipation. You'll be able to run 9.5 compression easily on 87 octane. Iron heads I'd stick to low 9s with a lower total timing advance. The ethanol in the fuel is helpful in being able to run more compression. But I'd aim for 9-9.2 if going with gt40. Being carb you have a huge selection of cams.
If your truck is already a v8 I wouldn't even consider the 300-6. They have some support for go fast parts, but if you're going to spend money on it (there are no aftermarket heads I can think of) you'll get more hp increase for your money with a 351.
on
Yeah that was with something around 9-9.3:1 compression ratio so it will be very pump gas friendly. Aftermarket heads will greatly increase HP potential making a 350hp/400tq build quite achievable but if you go beyond that in search of bigger horsepower low rpm torque begins to fall unless compression is raised
The truck is a 78 half ton shortbed 4x4. I think the drivetrain will consist of a ranger torque splitter, np 435, and np 205. 9 in and Dana 44 3.73 gears and a tire somewhere in the 31- 33" range. The goal is a reliable truck that can be a daily driver, do some mild offroading, and pull a pop up camper. Reliability, longevity, and fun to drive. 17ish mpg is what I'm Hopin for as well. You guys have me sold on the Windsor. I'm hoping to keep the cost of engine, rebuild, and performance parts around $4k. So what's the best aftermarket head on a budget for low end to midrange?
Since any aluminum head is going to be better then a pair of cast iron GT40's you only need to look for ones with smaller port volume and smaller valves then some other aftermarket head. A set of AL heads with 2.02 intakes and 205CC port volume will produce less torque at low RPM's then a head with 1.9 intake and a 185CC port volume all else being equal. That's not to say that you can't build an engine with the big valves and not make the same or more torque then the smaller valve head you just would use a different cam, compression, or intake.
I've got a buddy with a stroker mustang. He told me a stroker lower end is close to the same money aw a stock one. If this is true how would that graph look with a 393 stroker with a lower duration more torque oriented camshaft? How long lasting and reliable is a stroker compared to a stock displacement engine? Mpg is pretty much gunna suck with 393 co I suppose
on
A 393 with the Edelbrock topend will make 450+ ft/lbs across the board, and for truck uses there's no need for anything but a basic nodular iron kit so it's relatively cheap.. but there's often no need to replace the crank and rods on a stock rebuild so I don't see it costing the same. There's also no reason a stroker motor should have any shorter life than as a stock motor.
