1975 Ford Ranger door weatherstrip
hey i have a 1975 ford ranger and i just replaced the weatherstrip that goes around the door frame on the cab that seals when you shut the door.i bought the weatherstrip from LMC truck and once i put them on the doors dont fully shut close due to the weatherstripping. im thinking its because their brand new and the rubber is still stiff...is this a problem anybody has also had??how long should it be before the rubber loosens up so my doors shut completely??
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
this is what my truck looks like i recently painted it myself in the past month im still trying to put everything back on it that i took off to do the paint and bodywork on it like trim and emblems
nice looking truck. From what I have read, most people have this issue after installing new seals. you will need to adjust your striker on the door jamb, and maybe even the hinges too. either that, or keep slamming them until they loosen up. you can search and see what a lot of owners have done as well
thanks man....im new to this site but i did look around on topics.i shut the door and it clips onto the striker good enough that it wont swing open while im driving down the road but it doesnt shut completely it just looks like it the door is cracked open im thinking the seals should loosen up but im wondering how long it would take. i installed them last week.
flaka,
Welcome to the forum, having been through this recently, I wouldn't mess with the hinges at all, (my opion only) but adjusting the striker plate for now will work, it will eventually wear, the warmer it is the quicker they will form, I've even used a hair dryer to help form quicker.
good luck
good luck
flaka,
good luck
good luck
