51 gauge panel & 51 cam bearings
Old 11-21-2010, 08:14 PM
okiemagman's Avatar
okiemagman
okiemagman is offline
Hey, new here. Got 2 questions. 1, any body tried putting mech gauges in original 51 panel? Also, am rebuilding 226 in my 51 F1. Ran into problem. Cam brng placements are .082 inch too big. Am solving problem by sleeving placements but was wondering if anyone had run into this before.
Old 11-22-2010, 01:26 AM
Julies Cool F1's Avatar
Julies Cool F1
Julies Cool F1 is offline
Hello and welcome to FTE.
Cam bearings I'll leave for the flathead guys.
As far as using the works for mechanical gauges installed in the stock housings and using the OEM faces, then yes I have done that and it worked well.
Are you doing this because you have converted to 12 volt or just prefer the reliability of the mechanical gauges?
I have a write up on how to do this and lots of photos. If you would like a copy of that write me an e-mail at babbiebuddie@***.net (unless you are Dale and I already sent it to you tonight)
Here's a pic of mine after conversion. The telltale give away are the needle stop pins and the temperature gauge rests on "C" instead of "H" as with the electric gauge:
Name:  9. Guage Package Restoration.JPG
Old 11-22-2010, 09:33 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Are all the cam bearings' shells 0.082" too large OD, uniformly? How do you plan to sleeve? Something sounds off there...
Old 11-22-2010, 08:32 PM
okiemagman's Avatar
okiemagman
cam brng
Yep, all brngs same. Brng have no # on them just a brand. It's stamped Lincoln in script. As to repair, I have an align boring bar. Bought a cast iron sleeve 2.253 X 2.320. Bored placements to press fit sleeve and then bored sleeve to correct size. Only thing I can figure is in 51 factory bored placements to big and instead of junking block, had special cam brng made. According to my dad (87yrs), in 40's ford had leftover small crankshafts for V8 ftatties and had special brngs made for them.Could't buy brngs for them. Had to buy new c/s. Thats all I can figure.
Old 11-22-2010, 08:37 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Wow, that's handy to have that kind of equipment around! Don't the sleeves need oil holes?
I've heard of the small bearing V8 cranks, seems like there was more to it, tho.
Old 11-22-2010, 08:45 PM
okiemagman's Avatar
okiemagman
Oil holes are drilled thru bus line holes(remove plugs and bypass) w/ long 1/4 bit
Old 11-22-2010, 08:59 PM
52 5 star's Avatar
52 5 star
52 5 star is offline
welcome to the site
Jolly Roger Joe
12-16-2014 09:44 AM
frb9883
02-16-2005 11:47 PM
andyjack
05-18-2004 01:25 PM
51truck
11-15-2003 03:53 PM
Quick Reply: 51 gauge panel & 51 cam bearings
