Loose pinion nut
Loose pinion nut
I've been trying to track down a vibration and decided that it could be the driveshaft or a bearing. I removed the driveshaft and found that the pinion nut is loose. Once the driveshaft was out I could get some lateral play, very slight, so I just snugged the nut a little and it went away. What's my best course to follow now as I have no idea what the original torque was. It's getting cold out and my garage is gone, so I need simple as possible at least till I have a chance in a few months when it gets warm again and I can do it right.
Received 5,160 Likes
on
on
on
2005 F150 4x4 Lariat 5.4
So, I suspect my pinion nut is loose. (got the truck 3 years ago and had a complete rear diff rebuild per the ford SB due to the rear end whine... I guess the pinion nut was not torqued right at the factory) no issues for 3 years and about 25k miles. around the 3 year mark I start to hear a slight clunking coming from the rear, directly proportional to the drive shaft rpm's. No sign of leaks, fluid level is good. I just pulled the driveshaft to check the u joints and they are fine, no play at all and rotate smoothly. the collar going into the rear end has play if I shake it in any direction. That's my clunking. From what I've read, a bad bearing will be loud, but shouldn't cause play like this. So I want to check the torque on the pinion nut since I've read so much about people having them just loosen up on their own. I'm just wondering if I should go by the 8-14 inch pounds of rotational torque for used bearings? if it's significantly loose, should I tighten it until the rotational torque is in that range? Since I'm not removing anything and it's already loose, I can't mark it and count my turns... that just doesn't apply here.
Ford77Pickup
02-10-2017 05:35 PM
nvrsadi
05-17-2016 05:19 PM
