Duraspark II Conversion - How To
#137
No. They are different. You want distributor part #30-2669 (Cardone Reman). I bought mine at Auto Zone for $45 (no core).
#138
#139
Spark: check your ignition box and coil to make sure they are working and go from there.
#142
#143
#145
I went back to the the thread in 80-86 and watched the video as well as read the posts. Given that you have ArdWrknTrk and JimsRebel helping, who are two of the best, I'm going to withdraw from the fray as more cooks tend to muddle things rather than help. So stick with them and they will get you through this.
#147
Thanks gary, And sean, Im begining to think that too... im thinking the harness or dist. is bad. The harness is out of a 1979 with a 302, and the dist. is out of a 1973 with the 300. but wait.... now thinking about it.... didnt ford come out with DS-II in 1976??? will a DS-I dizzy be compatible with DS-II module/coil???
#148
My advise, would be to get a reman distributor. I posted the part # for the one you need earlier ($45 + cap/rotor and spacer) at Auto Zone (for 1980 F150). Also, unwrap the ignition harness and check for issues (cuts in wires, etc) and then re-wrap it...reg. Black electrical tape works good...spiral wrap it.
I used the reman distributor w/30-year old OEM ignition module, coil, harness...and literally plugged everything in and it ran great. There really isn't a whole lot of room for error or issues.
#149
SUCCESS! I got it started, i tinkered with the dist. and it was WAAAAY out of time. Now i have a new problem... the gas in the carb bowl seems to be over filling and gas is pouring out the nipple next to the fuel inlet on the carb... why is my fuel bowl getting over full? i am also running 3/8 rubber line, could it be feeding to much gas to the bowl? should i convert back to the stock metal line
The following users liked this post:
#150
