Duraspark II Conversion - How To
Old 12-16-2010, 10:05 AM
JimsRebel's Avatar
JimsRebel
JimsRebel is offline
Originally Posted by Tomcat45
Does the EGR stay hooked up to a vacume source, or just left in place to act as a plug?
Thanks for the quick reply.
I removed the EGR and put a thin piece of sheet metal (beer can) between them and reinstalled it. I also used high temp silicon gasket sealer.
<O</O
It is not a bad thing to have the EGR working properly, I just haven’t figured out how to do that with the stuff I currently have on my truck. I don’t think it would be cost effective to spend money on trying to fixing it.
<O</O
Jim
Old 12-16-2010, 11:55 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
<O</O
<O</O
Jim
I did the same thing for blocking off the EGR valve on my truck some 10 years back. A few months back, I took it loose, and the thin metal had 2 holes burned thru it, re-enabling the EGR......
Ok, it was a soda can, since I don't like beer.
Old 12-19-2010, 03:36 PM
LARIAT 85's Avatar
LARIAT 85
LARIAT 85 is offline
GREAT pics! I just thought it would be helpful to link these two posts:
https://www.ford-trucks.com/forums/9...wontt-run.html
Old 01-08-2011, 08:57 PM
kedwinh's Avatar
kedwinh
kedwinh is offline
Great writeup. So if I am reading this right, I can remove ALL vacuum lines except brake booster and vacuum advance?
Old 01-08-2011, 09:56 PM
Rogue_Wulff
Not all, but most. If you have A/C (working or not) the system relies on vacuum to change from floor/vent/defroster.
You need to leave the PCV system fully intact. *Important*
There may be a few other minor things that need to stay as well.
Old 09-26-2011, 02:11 PM
Monte1go's Avatar
Monte1go
Monte1go is offline
Bump this thread
Old 02-16-2012, 06:11 AM
blkgolfer1's Avatar
blkgolfer1
blkgolfer1 is offline
One more question please.
Do I have to use a distibutor that has the newer non-points and condenser version or can I use the older model with the DSII system? Also now that I think about it, what about the valve cover hose or breather that goes to the air cleaner? The rest of your write-up was fabulous and I printed it off and am doing this conversion on my 86 F150 I6.
Old 02-16-2012, 09:00 AM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
I believe you have to use a DSII distributor, since it has the required wiring harness plug in, but I'm not 100% on that.
As for the hose, there's a current thread going on about that.
https://www.ford-trucks.com/forums/1...vent-hose.html
Old 02-16-2012, 09:18 AM
blkgolfer1's Avatar
blkgolfer1
The distributor that I have that has the points and condenser has the same wiring harness plug as the DSII one. I was thinking the points and condenser type was even more "low-tech" than the DSII type. Maybe my understanding of the DSII is misconstrued and it is "low-tech" but more reliable than the points and condenser type. Any ideas?
Old 02-16-2012, 11:24 AM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
I'd like to see a picture of that, with cap off, as I have never ran across it.
Old 02-20-2012, 05:29 AM
blkgolfer1's Avatar
blkgolfer1
I will see what I can do for you. I have been gone all weekend and am just catching up on things right now.
Old 02-27-2012, 03:43 PM
millboroman's Avatar
millboroman
millboroman is offline
I recently converted my 86 f-150 to the duraspark system, I bought a new carter 1 barrel for it. The truck starts instantly, however it's only getting 8 mpg and it's flooding it's self to death idiling. I am not certain I have the vacuum lines right. I have the bottom hose to the distributor. The top one is going to the heat tube. The bottom pcv hose is going to the egr plate under carb and the top pcv port is plugged. The brake booster is fed from the large port on the tree. I have adjusted the carb to 11/2 turns out on the mixture and adjusted the idle. Do I need a new carb or what?
  #28
Old 04-29-2012, 06:57 PM
Leddyledford's Avatar
Leddyledford
Leddyledford is offline
Did you have to have the motor at tdc when exchanging the distibutor?got my swap done this weekend but i can't get it to start. Not sure if it's the wiring.
  #29
Old 08-07-2012, 01:53 AM
uncleJim97's Avatar
uncleJim97
uncleJim97 is offline
Anyone ever heard of trying the aftermarket Ford 6 distributor that runs a GM HEI module? Thinking that it may be the better way to go since everything is incorporated into the cap and is a one wire hook up ( Not counting the tach wire. ) Found a place on Ebay that sells the one's for the small Block Ford, but not the 240/300 4.9 sixes. Hey thirty bucks plus shipping is quite appealing to the pocket book!
  #30
Old 08-07-2012, 05:41 AM
zombiehunter's Avatar
zombiehunter
zombiehunter is offline
DUI makes an hei distributor to fit the L6 but they are a bit pricey, i use them alot on v8's super simple. Ford DUI - Street/Strip Version
Quick Reply: Duraspark II Conversion - How To
