Any Ideas !!!!!!
Old 11-22-2010, 08:25 PM
Shaun lindmark's Avatar
Shaun lindmark
Shaun lindmark is offline
Originally Posted by tjbeggs
Gonna need to test fuel pressure under load. Could be dropping too low under load
I will try it but that would be to test the regulator right ? If so wouldn't it not run right all the time whether the chip was in or not
Old 11-23-2010, 05:32 AM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Its to test the overall fuel system. You have to do the simple basic tests before you start the chase on sensors and what not. It doesn't seem like it could be the issue but if we don't test it now you could waste a lot of time if for some dumb reason its the problem!
Old 11-23-2010, 06:03 AM
Muktown's Avatar
Muktown
Muktown is offline
Could it possibly be in the go pedal? Maybe diablo increases voltage to it to make it more responsive and its just enough to cover up a dead spot? Just a wag.
Old 11-23-2010, 08:44 AM
Shaun lindmark
That's what we thought too but the scanner showed the correct voltage.
Old 11-23-2010, 08:47 AM
Shaun lindmark
Good point I will try that soon. What should the pressure be under a load? And where should I take the reading from ? .. on the regulator where I tested it at idle
Old 11-23-2010, 11:19 AM
Shaun lindmark
Ok just checked the map line its as clean as a.whistle. defiantly not restricted at all
Old 11-23-2010, 02:21 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Spec is 40-70psi tested at the same place you tested at idle
