1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Show me pictures of those SUPER DUTY'S working.
Old 08-01-2011, 02:32 PM
raidscsi's Avatar
raidscsi
raidscsi is offline
That's a LH3000, there are a few tricks to using it, paid $150 online for it. Well worth the money.
We have horses and buy sawdust regularly. We are lucky to have a sawdust reseller within 15miles that sells 1 yard for $14, a lot cheaper than buying bagged sawdust. In any case unloading 3 or 4 cubic yards of sawdust by hand is not fun. This thing makes unloading the truck a 30 second operation. Loading makes all the difference, with a big load like sawdust it doesn't matter because it fills the bed, but with gravel the more you get onto the tarp the less you have to do by hand later. We have used it to move gravel, sawdust, mulch, manure, wood for bonfire. It is very hefty.
My dad wants to make a bed insert out of plywood that is V shaped similar to the bottom of a dumper dog bed insert so that the wheel wells don't catch the extra material. Would say that a plastic bed liner is better than a stock bed. I would guess that a rhino lined bed wouldn't work well.
Also don't let the crank arm hit you in the leg.
  #317
Old 08-01-2011, 02:49 PM
sammy77's Avatar
sammy77
sammy77 is offline
Not exactly work but....
  #318
Old 08-01-2011, 04:03 PM
davidjurss's Avatar
davidjurss
davidjurss is offline
Originally Posted by Eatonpcat
Nice Center Console...What size??? 18,19 foot??
Thanks. Its an 18ft Sea Hunt Triton.
Ended up breaking the prop shaft about 20 minutes after putting it in the water. Had to get towed back to the ramp. Luckily I was able to get another boat and salvage the weekend.
  #319
Old 08-02-2011, 01:26 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is online now
9 ECHO 1
Does it ever bind up or struggle under heavy loads?
  #320
Old 08-02-2011, 07:42 AM
raidscsi's Avatar
raidscsi
raidscsi is offline
Its hard to explain, part of the science behind how the load handler works is that the tarp itself is stretchy. So that when you first start moving the load it happens in a wave from back to front. The amount of mechanical advantage you get from the handle is surprising. I think that the tarp would rip before you found a load that was too big to move.
  #321
Old 08-02-2011, 08:52 AM
ItsMREMT's Avatar
ItsMREMT
ItsMREMT is offline
pulling a few loads of dirt
compacting the dirt
  #322
Old 08-02-2011, 08:59 AM
ItsMREMT's Avatar
ItsMREMT
ItsMREMT is offline
I dont think there is a weight limit I use something similar at work the more weight applied to the tarp the better it works. they way it was explained to be is that it works by cuting down on the amount of friction between those two objects allowing you to slide it
  #323
Old 08-02-2011, 03:27 PM
ETKMS's Avatar
ETKMS
ETKMS is offline
I am shocked that 90% of the trucks posting pics here are SRW, i would have thought more DRWs would be posting pics....
  #324
Old 08-02-2011, 03:31 PM
acf6's Avatar
acf6
acf6 is offline
this one is on the right in the picture above, 2004 F550 6.0. my uncles truck we use for installing pools
  #325
Old 08-02-2011, 03:33 PM
sbowling79's Avatar
sbowling79
sbowling79 is offline
cant upload wtf
  #326
Old 08-02-2011, 03:37 PM
sbowling79's Avatar
sbowling79
  #327
Old 08-02-2011, 04:00 PM
BigPigDaddy's Avatar
BigPigDaddy
BigPigDaddy is offline
I think the DRW owners are too busy working to be posting pics.
  #328
Old 08-02-2011, 04:57 PM
buck_'s Avatar
buck_
buck_ is offline
Here is my new dually. I got it on Friday. It's a 06 F350 V-10 6 speed 4X4.
Not much of a load for this truck, just some scrap steel to get rid of.
  #329
Old 08-03-2011, 08:18 PM
SoCalGT08's Avatar
SoCalGT08
SoCalGT08 is offline
2006 F350.....work'n .
  #330
Old 08-03-2011, 08:55 PM
MDSuperDuty's Avatar
MDSuperDuty
MDSuperDuty is offline
Pulling a 14k dump trailer
Quick Reply: Show me pictures of those SUPER DUTY'S working.
