2003 5.4 in to a 1999 5.4 250 SD
Old 11-20-2010, 03:36 PM
TBFGhost's Avatar
TBFGhost
TBFGhost is offline
Thank you for your detailed post. I noticed that the motor mounts seem really easy to get to if you unbolt them at the frame...rather then splitting them in half or un bolting at the motor...anyone else try this?
Old 11-23-2010, 02:10 PM
tawells01's Avatar
tawells01
tawells01 is offline
I managed to just unbolt the mounts from the crossmember. It seemed the easiest way to do it.
Old 11-23-2010, 02:44 PM
TBFGhost's Avatar
TBFGhost
TBFGhost is offline
That is how I was planning on doing it.
Here are photos of the replacment motor at the machine shop. Torn down and inspected. Block is good, no cracks or anything. The cyls are JUST with-in tolerance...and you can still see the hone marks. It going to be bored over .030 to besure everything is perfect. The cranks is going to be ground down .010...I am willing to be the guy who had the motor used too thick of oil in it...starved the bottom end b/c the top end seems just fine. The heads are good to go..no major machining work needs to be done. Said the cyl all look to be firing correctly as well.
Old 11-29-2010, 04:43 PM
TBFGhost's Avatar
TBFGhost
TBFGhost is offline
I just stopped into the machine shop to talk to the guy and noticed they had a new PI 5.4 sitting there with an old core waiting to go ito another 250.....I might be getting the cam shafts from that core PI motor... and I am also having him mildly port the intake and gasket match things.
Old 12-06-2010, 08:57 PM
Skoda's Avatar
Skoda
Skoda is offline
https://www.ford-trucks.com/forums/1...r-install.html
there might be a few usfull pics here.
Old 12-06-2010, 09:11 PM
Skoda's Avatar
Skoda
Skoda is offline
agreed easyer by the frame bolts, did it with the V10 and V8
Old 12-06-2010, 11:21 PM
TBFGhost's Avatar
TBFGhost
TBFGhost is offline
Thanks guys
Old 12-07-2010, 09:11 AM
TBFGhost's Avatar
TBFGhost
TBFGhost is offline
While I am in there and puttin in a new motor I will be replacing things like all the coils, Fuel Pump, any and all filters, I want to send the fuel injectors to be cleaned etc. Are there other sensors or solenoids that tend to go bad with time more then others that would be wise to replace now?
Kinda I do it now before I have to do it later type thing.
Old 12-07-2010, 06:37 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
I replaced everything from the knock sensor, which is under the intake, to the oil pressure sensor and the heater hoses. Also the IAC and TPS I am also replacing the starter and power steering pump, idler pulleys, belt tensioner. It all add up however, I probably have more money in sensors and accessories than I do in the engine. I also replace my torque converter since it is sitting there in the open.
twall_SD250
1999 to 2016 Super Duty
08-10-2016 04:54 PM
Pete Kildow
1997 - 2003 F150
08-04-2015 07:46 AM
tdmontg
1997 - 2003 F150
06-02-2013 02:49 PM
sparkey02
Engine Swaps
05-22-2012 04:29 AM
BACKWOODS99
Engine Swaps
03-05-2011 09:23 AM
Quick Reply: 2003 5.4 in to a 1999 5.4 250 SD
