HOw much Oil does it need?
Wow really 15k that's nuts I meant I would atleast change it 10k just to be on the safe side but I have 6.8 4X4 so the cost on that would make sense
Dammmn 16Qts!!! No wonder they charge 250 for a tranny flush!
If you truly were able to change out all of the fluid then the 4R100 holds about 16 quarts depending on which pan is on there (4x2 or 4x4). Doing a drain and fill of just the trans pan is about 5.5 - 6 quarts. I believe the RP Max ATF only comes in quarts or in 5 gallon containers.
PHOTOG101
07-16-2023 10:08 AM
