Track Bar
now days we're talking heavier leaf packs, wider springs, and tougher bushings.
you should be ok to drive it with out the trac bar. if you think about it, your leaf springs are pinned to your axle (the stud of the leaf pack sits in a hole on the axle mount). as long as your u-bots are tight, your axle is secured to the springs, the springs may have some axle wrap issues, but doubt you'll see/feel any of these issues given that you don't do any crawling, or hard mud bogs. we have a "sway bar" on the front as well, so your turning sway will still be slim!
trac bars serve more of a purpose on a coil over type suspension where the is only coils and shocks. the bar will keep the axles centered, and the radius arms provide a traction bar type stability (limits axle wrap, as well as front to back movement. all these things that effect a coil over type suspension dont really apply to a sprung type suspension.
leaf springs provide the combination of radius arms (no front of back motion of the axle), as well as a trac bar (no side to side movement). it has also been shown that a trac bar is some times put into place to provide engine torque stability. when accelerating under a load, your torque shift of the engine will some times flex the frame / suspension. a good example is an 18 wheeler. when the start off from a stop light you'll watch the body, cab, and suspension flex. the right side spring will compress as the engine torques, lifting weight off the left side tire.... a trac bar will eliminate or at least cut way down on torque flex.
because those older trucks had shackles/leaf springs/ and bushings all DESIGNED around holding the axle in place..
under a SD they are part of the suspension system not all the peices..
its your truck but i'm just saying your putting stress on parts that might not be able to deal with it when cornering/braking..
your call..
your call..
your call..
your call..
