95 powerstroke swap into 78 f250
I have a great donor truck almost to sad to use as a donor truck but none the less is . also no rust 78 f-250 needs rear end work no big deal but tired of 351m engines junk junk junk. fabricating intake exhaust engine mounts trans drive shafts i can do but there will be a whole lot of wires i dont need and new to the diesels what wires i need can i still use programmer what boxes do i use what dont i use just nervous to start but one way or another ima get it done just asking for help and know hows. thanks
earthresin, I know what your saying. I have a 80 f250 4by4 in perfect condition with a 302 that doesn't run. I also have toyed with the idea of a swap. I've read on here that same question for six years now and the majority of the answers to your question is: its a lot of work and you would be better off just buying a truck with a PSD in it already. Yes, it can be done and if I may quote you, "but one way or another ima get it done", that's the only way you'll get it done-ambition and never taking no for an answer!!
Dont forget Ethan, the accellerator pedal will be needed from the PS as well.. Its sensor operated!
Glenn.. Thats the truth behind it! My project was a little long going, and would have been done sooner had the heat not come on so soon, LOL, but its worth it, and really when you look at it one thing at a time, is not that much work!
I say go for it and do it! I seen a PS put in one before, and it takes just a little craftyness!
