EFI 351 windsor 5.8l
Won't win you any races, 4.10's help it alot. So will some full length headers and a good exhaust. I too had diesels, and they are a different animal.
I think it's best years were 96 and 97 but it does fine. You pulling alot with it, hauling super heavy? You might feel unimpressed with it after coming from diesels.
i got a 97 f350 with the 351 and e4od. It does my dads skid steer and trailer ok, the people behind you are gonna have to wait for ya to get up that hill but atleast you can pull with it. The trailer and skid steer are around 8600 pounds total, so its pretty heavy. I can pull the hills here at 35 to 40 MPH foot to the floor doing 3000 RPM.
ya 3.55's with 35's it's gonna be lacking alot of power. I put 33's on my truck and ive got 4.10's, I can feel the difference in power. you should ether put like 4.56 gears or go smaller tires. The five speed will help you out better then a auto though. Hey if you like the truck go for it there pretty reliable I like mine myself, as long as its not rotted or looks like a fricken lowrider, you should be set.
oh ya make sure that the long bolt that goes through the water pump and timing cover isn't broken off, I forgot to look at that on my truck, now I got to take the motor apart to get to it. almost all of the long ones break, oh well just look the truck over really good before you buy. Just my 2 cents
I run stock size tires, E rated. With the 4.10s it pulls pretty decent. 168k on the ticker and nothing replaced but wear items.
I'd lose the 35's or gear up. Or both if your gonna work it.
Mine pulls 6k-8k regularly and does it fine. Not quite as fast as the PSD I had, but it gets the job done just fine.
