2 wheel drive questions
ok, so i work with a guy that has a rust free california truck for sale and he said he'd cut me a deal on it (5-$600) he won't have the title back for a month or so because it just got switched to his name. the first and only other owner is his brother who bought it new. the truck was used to tow a 15k trailer from time to time and i assume that is the main reason for the only issue it has.
truck specs:
1984 f250 2x4 460, c-6, power options, and i believe a/c.
the tranny took a **** but 1st and second still kind of work. motor is in great shape with103,xxx original miles.
idk **** about 2x4's but it has a radius arm setup that looks pretty similar to the 4x4 half tons. are the f250 front suspension the same as the f150's? i know that you can bolt all of the ttb crap into a 2x4, so what i was thinking is if the frames are the same on a 250 then i could try to get this set of axles from a guy on another forum. d60 and a sterling from a sased bronco, has all of the brackets and suspension(rear springs ftw!!!!) included and i believe high steer setup and some half tread 36's on rims for roll arounds all for a very reasonable price. if the frames are the same this would be a simple way to get a sweet truck put together for next to nothing of an investment.
so if anyone knows if f250 2 wheel drive front suspension and frame dimensions are the same let me know.
next question, if the frames are the same do you guys think that selling my bronco for a reasonable amount to fund buying this is a good idea? wife kind of said i don't have the room here to have more than one extra vehicle, so if i get this the bronc has to go, it's the truth, no parking room
here's some pics for judgement. i <3 80-86's.
truck specs:
Received 3,108 Likes
on
the only problem is that 2 wheel drive trucks have coil suspension.
you may want to look at a 05 and newer superduty for axle swap. they have front coils. but you would also have to swap the rear rear in also to get matching wheel bolt pattern, or carry 2 spare tires. but putting the rear rear in would give you 4 wheel disc brakes, so that is an extra.
yep, dave got it. d60 setup for coils and radius arms on a 80-96 f150 or bronco 4x4. either way, even if i gon't get those axles i still think i want this truck more than the bronco. like bender said, its just too g/d nice to pass up. i love the body style of 80-86's but all the local ones are shot to hell. gonna try to get it, but money is killer tight with the new baby. maybe i can work something out.
helihansen
58
01-09-2018 01:01 PM
