How many sunroofs
There's one in a junkyard around here. Lookswise, I'm a big fan. But ya all I've ever heard, and what I would immediately assume is that they leak like crazy, and from the two I've seen in person, all the precision cutting, metalwork, shaping and sealing involved, is just an invitation for rust all around the edges. I saw a truck once that had one with etched glass though, like this wilderness scene that I'm sure caught the moonlight and all that, and it looked AMAZING.
I've get a set on my truck and they are kind of neat and fun to have, if I had the choice I would not but them in. The previous owner put them in, the holes were not cut all that great, however they have a little bit of a lip to overlap with the roof to hide this a little bit, plus he had gobbed silicone around it to hide this further however they still leaked.
I had to take them out this summer to paint the cab. When I reinstalled them I made sure to take off all the old glue and silicone. They were a pain to get back in then to get screwed in, however that could be from the shotty job done initially. I re-sealed them using some weatherstripping compound, or something of the like. The passenger window does not leak at all however the driver's window leaks pretty badly. Also, there is a big **** on my setup to open and close the window, and being a taller guy I tend to hit my head on it... luckily I haven't hit a large bump yet.
If I had my choice, I would definitely NOT do this, however if done correctly they will work adequately. Here's a few pics of my truck for reference.
I did it to an 81 flareside I owned.
I bought the whole thing for around 100 bucks from pep boys back then. They used to have them on the shelf. My dad and I measured quite a few times and then cut it out with a sawzall.
I got lucky on placement because I did not take the sunvisors in to account. I did clear them though. I had no issues with leaks. Mine was a one piece removable roof.
It was nice for airflow when you do not have a/c. I also installed a sliding back glass. With all the windows down it was similar to a convertible. I liked it.
Is yours completely removable?
I did not notice mine was at first. It had a little latch on each hinge when opened, the whole thing came out and set behind my seat.
Mine is completly removable. The front has metal tabs that fit into slots and the back of it has a latch that allows it to open about 2 inches or so.
