I have my 06 F-550 C+C, with a V10 in it, and as soon as you hit 3000 rpm, it falls on its face and bogs and as soon as you put the gas petal past 1/4 throttle it bogs and falls on its face....... but if you keep it at low rpms and not much gas it runs fine..... Any ideas???? No codes on the truck either.
checked the fuel pump today and we got 75 psi on the meter when connected direct to it
Ah, but, do you have that pressure above 3000 rpm, where the problem is?
Where does youre egr kick in?
Fuel regulator, or variable pump speed(returnless) system?
There is no return on the pump, so it is the variable speed. And i dont know where the place to hook up the pressure gauge is. We took the line off the pump and hooked it up direct and got that reading, where else could i get that reading?
im pretty sure your catalytic converter is clogged...
Agree. This is exactly how my old F-150 acted when I had a clogged cat. Around town it was fine. Out on the highway, put your foot into it, it would down shift and slow down.
