No intermittent wiper or slow speed
88 f150. Just bought the truck and it didn't have a **** on the wipers. Dash mounted switch. The switch wil turn both ways from the off position. clockwise does nothing on the first click. 2nd click is high spd and the only setting that works. from the off position I can also turn the **** counter clockwise. That also does nothing. I am thinking that the ccw side is the intermittent function and that the first cw setting is a low setting. The washer works but does not move the wipers. After my searches I think that it sounds like I have a bad governor, if I do have the intermittent function. This is my first ford of this vintage so I am completely unfamiliar with how the wiper switch is supposed to function properly. Any help would be great. If it does sound like the governor, then where might I find it. I think it might be next to my fuse box. thanks in advance, Joe
This is a common problem.
You need the intermittent wiper governor module that plugs between the switch and harness. (or you can try resoldering the leads inside this expensive little box)
On my '87 it is mounted on a metal arm attached over by the parking brake.
The wipers don't move with the 'push for washers' function.
Turning it left increases the duration between wipes.
https://www.ford-trucks.com/forums/8...r-problem.html Have a read through the thread in this link.
Just says what Ard says but in more detail.
Rogue_Wulff
27
12-18-2016 08:59 AM
devino246
05-23-2013 11:23 AM
Hamberger
01-30-2006 09:31 AM
Mike in RI
21
07-12-2004 10:20 AM
