6.8 V10 95 to 130 amp alternator swap?
Not sure if this should be here or in the "6.8 V10" area. According to some parts info I found on the Internet, my 2000 F250 SD 4x4 with the 6.8 V10 comes stock with a 95 amp (small case 5 1/8") alternator. I noticed that the Excursions come with a 130 amp (large case 5 5/8") alternator. I was wonder if I can upgrade from a 95 to a 130 since I carry a Lance camper?
You would have to upgrade the wiring also. Don't you have a battery in your camper? And it's charged from the truck correct? I believe the charge circuit from the truck is only around 30 amps, and slowly charges while you are driving. Unless you have some other special need for a higher amperage alternator.
I have never done the swap, but like you said it was an option, so I am sure it could be done. I cannot tell you though, if you would need a new alt bracket. But I am sure you would have to upgrade the wiring to the alternator, and if you do have a high amperage device you are running, it will need it's own wiring, not the truck's original wiring.
wizzy214
15
09-19-2012 09:57 AM
