Greasing Rebuilt Front end for the first time
Hey all I recently reassembled my front end king pins and spindle part of the drag link. The bottom grease fittings of the king pins took the new grease pretty easy but the drag link end took it about 1/3 as well and the upper grease fittings on the king pins took it even harder. But they did take some...is this normal do you think due to new parts and should it improve over time as things wear in a bit? thanx
Yep that's pretty normal.....The tie rod ends will be almost impossible.
Something that makes it easier is to lift the weight off the wheels and have one of your neighborhood kids turn the steering wheel while you are trying to grease. Make sure the truck is solidly on jack stands while you do this.
should be upper and lower zerk on each kingpin you need grease coming out of all moving points where the kingpin rotates left and right on the axel spindle ,,, crank wheels left and right ,,, keep driving grease in till it's all over you .. the spindle ..the floor ,,, you did test the zerks when you had the kingpins out ,, and cleaned the holes behind the zerks of that 40 yr old caked in crud the grease turned into 35 yrs ago ??same with the drag link ,,, you want grease spurting out from under the rubber cover .. try with the wheels off the floor ,, or on the floor .. done lowers with truck down ,, upper with truck jacked ,,,
Cracker289
29
08-04-2015 07:40 AM
salf100
11-26-2012 11:25 AM
windsor8689
02-28-2011 09:58 PM
sweet potato
02-15-2011 03:51 PM
rog_j
05-02-2003 05:51 AM
