94 hard to start and keep running
It has a long crank, then it starts and idles rough for 10 min or longer. If you try moving it, it dies and then has a even longer crank and you have to hold the starter until it can stay running. If you let it idle for a good 30 min the idle smothes a bit and can actually drive it.
I'm suspecting it has a bad glow plugs and gp relay. Anything else I should check out??
