1966 VIN# decode Information
#107
Need some help decoding my VIN
1966 F-100.
VIN#: F10YR820256
I am trying to figure the engine--some years have the Y but in all my internet research I can't seem to figure the Y on the '66. Assuming it's the 351?
Also is there a way to figure out the DSO?
Mine says 74.
Any help for a new Ford guy would be awesome!
VIN#: F10YR820256
Mine says 74.
#108
Welcome to FTE. The 351 truck engine was not available as early as 1966. What was available was a 352 cubic inch FE V8 (the 351 is a Windsor), and it was the only V8 available in the F100 for 1965 - 67. The Warranty Plate code for the 352 was "D" for the 1965 model year and "Y" for the 1966 - 67 model years. How 'bout we give you the full decode: F10 = 2 wheel drive F100 truck. Y = 352 cubic inch 2 bbl FE V8. R = San Jose, California assembly plant. 820256 = assembled in February, 1966. 129 = wheelbase in inches. J = exterior color Rangoon Red. F100 = half ton truck with 5000 pound Gross Vehicle Weight rating. E81 = Red upholstery (you'll get further information from others on this). A = New Process 4 speed manual transmission. 08 = Ford 9 inch non-limited slip rear axle with 3.50 gears. 5000 = GVW rating in pounds. 172 @ 4000 is the engine's NET horsepower rating and the RPMs where achieved (GROSS HP is rated at 208 which is what's on the air cleaner decal). 74 = Seattle, the District Sales Office from which the truck was ordered. Your truck was NOT special ordered. Keep in mind, previous owner's may have altered your truck from the way it was delivered, but at least this gives you a starting point. Hope you enjoy your new truck.
#109
#110
1966 vin
Hi. Newbie, first post. Just bought a1966 f100 custom cab and I am taking you up on the offer in this thread to have my vin decoded. f10yn830458 door stamp:
129 B f100 c81 c 17
5000 172 4000 22
Also, the guy I purchased from said there is a mid 70's 390 in it with a four speed trans. Any help on how to id those more exactly would also be greatly appreciated. Thanks!
129 B f100 c81 c 17
5000 172 4000 22
#111
Y = 352 2V
N = Norfolk VA Assembly Plant.
830458 = 1966, assembled March 1966.
129" Wheelbase.
B = Caribbean Turquoise.
F100 2WD .. 5,000 lbs. GVWR
C81: C = Medium Green Crush Vinyl & Medium Green Cody Pattern Woven Plastic / 81 = 81B Custom Cab.
C = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
17 = Ford 9" Rear Axle / 3.25-1 / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
22 = Charlotte NC Ford District Sales Office, where the original selling dealer ordered the truck from.
On sale day 352/360 engines magically become 390's!
Mid 1970's 390 would be from a F100/350, because 1971 was the last year 390's were installed in cars.
360/390 factory installed in 1968/76 F100/350.
Measure the stroke to determine engine size: 352/360: 3.50" / 390: 3.78."
If the 4 speed is from a truck, it will be either a Warner T-18 or a New Process 435 (NP435).
T-18 shift lever retainer cap threads off/on.
See pic below: NP435 shift lever retainer cap (7220) has two notches, is retained to the shift tower with two pins (7221).
#112
I'm also somewhat new hear, I haven't been on the site much since I sold my F150 a few years ago. I bought a 1966 F100 step side short box off line. I haven't seen the truck in person yet and won't until I get back from overseas in October. I'd like to know more about my truck.
VIN: F10YR803308
VIN: F10YR803308
#113
I'm also somewhat new here, I haven't been on the site much since I sold my F150 a few years ago.
I bought a 1966 F100 Flareside (a step side is a Chevrolet ) short box off line. I haven't seen the truck in person yet and won't until I get back from overseas in October.
I'd like to know more about my truck. VIN: F10YR803308
Y = 352 2V
R = San Jose CA Assembly Plant.
803308 = 1966, assembled January 1966.
The VIN when decoded, don't tell you much. Post a pic or all the codes stamped on the Warranty Plate, riveted to the left door below the latch.
#116
#118
D = 352 2V
581051 = 1965, assembled August 1964.
129" Wheelbase.
W = Marlin Blue.
B81: B = Medium Blue Crush Vinyl & Medium Blue Ladder Pattern Woven Plastic / 81 = 81B Custom Cab.
N = New Process 435 4 Speed Manual Transmission.
08 = Ford 9" Rear Axle / 3.50-1 / 3,300 lbs. Axle Capacity.
172 net HP @ 4,000 RPM (352 2V).
72 = San Jose (NorCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
Last edited by NumberDummy; 11-24-2016 at 11:49 AM. Reason: Edited in further information.
#119
911Tom, would you mind typing in your wheelbase, color, model, GVWR Lbs. and DSO? I can guess that your HP is 172 and RPM is 4000.
In 1964-1971 they actually had an F100 (5,000 Lbs.), F101 (4,200 Lbs.) and F102 (5,000 Lbs - state of Pa.) - all different GVWR Lbs. than each other, or Pa. I have not delved into years prior to 1964 for this minutiae.
And then 1972 changed all that up again and added more models, but luckily we don't have to concern ourselves with that here.
#120
In 1964-1971 they actually had an F100 (5,000 Lbs.), F101 (4,200 Lbs.) and F102 (5,000 Lbs - state of Pa.) - all different GVWR Lbs. than each other. I have not delved into years prior to 1964 for this minutiae.
