early heads work
Yes, but if you lay an early head gasket on your later block, you will see a water passage near the front that will need to be tapped and a flush plug screwed in. One time I helped a fella replace his head gaskets. The package (Napa) surprisingly contained one late/one early gasket. You know what happened when he started it to check for leaks...yep, he found one.
Just be careful of corrosion with used aluminum.
edit: morning Ross : ) you beat me today
