is there away to adjust the gear shifter
Old 10-22-2010, 11:27 AM
twisstedex's Avatar
twisstedex
twisstedex is offline
my reverse lights and back up alarm will not ingage unless i hold up on the shifter while in reverse the only thing i found was a adjuster for the indicator .any one else have this prob
Old 10-22-2010, 02:21 PM
jh818's Avatar
jh818
jh818 is offline
Maybe you need to replace the bushings for the shifter?
Old 10-22-2010, 02:47 PM
wallz's Avatar
wallz
wallz is offline
I would take off the covers on the column and take a look at the bolts holding everything down. You may find some loose causing the issues.
Old 10-22-2010, 04:49 PM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is online now
Retired Mod
1. Move your driver seat all the way back
2. Remove the lower dash (4 thumbscrews)
3. Chock the wheels and set the parking brake
4. Get your keys and turn it to the first position
5. Drop the shift lever into 1st
6. Lay on your back and look up while gently moving the gear shift and you'll notice two brass colored screws that are either loose if not about to fall out.
7. R&R the two torx screws with some loctite and never worry about the problem again. Worked for me!
The following users liked this post:
Old 10-22-2010, 08:21 PM
gr8scott72's Avatar
gr8scott72
gr8scott72 is offline
I did this to mine recently but without doing steps 3, 4, or 5.
One of those two screws had fallen all the way out and my truck wouldn't shift into park at all.
Old 10-23-2010, 06:27 PM
sddesigns's Avatar
sddesigns
sddesigns is offline
Here is what they look like! The two brass colored screws directly up from my finger, don't remove both screws, if they are loose tighten up one, then remove the other put a drop of red Lock-Tite on it, then tighten that one down, and repeat on the other one.
Old 03-13-2011, 03:49 PM
StickMonkey's Avatar
StickMonkey
StickMonkey is offline
Steps worked perfectly. Need a T30 torx head.
Old 11-17-2011, 10:54 AM
dockrocker's Avatar
dockrocker
dockrocker is offline
Does this tighten up a "loose" gear level? The shifter on my 2000 is wobblier than a politician on election day....
Old 11-17-2011, 12:03 PM
sddesigns's Avatar
sddesigns
It might, I know mine was tough to get in park, and they both were ready to fall out. But I still have some play and I'm gonna be replacing the Transmission Shift Position switch this weekend.
I did PB Blast it and it already seems to be a little better, and it might also just be the cable needs some lube.
Old 11-17-2011, 12:49 PM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
It took me 3 attempts before I figured out where to look.....
I kept looking up under the steering column under the wheel,
I even removed the lower cover on the steering column....
Finally I stuck my head down by the brake pedal and
look BACK up the steering column. THEN I found it.
After I tightened those 2 torx screws my shifter is much better.
Thanks for this info!
Old 11-18-2011, 09:16 AM
dockrocker's Avatar
dockrocker
And thank you for that update - I stuck my head in there this morning and could not for the life of me find those screws. Will give it another shot later today!
Old 11-28-2011, 03:15 PM
dockrocker's Avatar
dockrocker
Got in there, found the screws, both are nice and tight but I still have a lot of play in the shift lever. Not sure what to do at this point, so I guess I'll just live with it.
Old 11-28-2011, 07:56 PM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
Cool, glad I'm not the only one that was baffled (or spoke up!)
Mine only wiggles a little bit now before it felt like it'd fall off.
Old 11-29-2011, 07:44 AM
Dan Reinbold's Avatar
Dan Reinbold
Dan Reinbold is offline
Same here, I tightened those torx bolts real tight. Still have a wobbly selector. I'll dig into it when I find the time.
Old 12-01-2011, 10:26 PM
Excursion4X4's Avatar
Excursion4X4
Excursion4X4 is offline
Just tightened mine up today. Had one most of the way out, and a loose shifter. Now both are good and tight and the shifter is almost like new!
Quick Reply: is there away to adjust the gear shifter
