52 Ford with a viper V10!
So here is another attachment, not sure if anyone has seen this thing but it is a real engineering acompishment. It's widended by 2 feet!
1952 Fiper SRT10 Viper
We try when ever there are new changes to keep our webpages up to date, last weeks It was the "Honey can you do list"
We'll be back in the shop soon again , keep you posted and thank you for your posting
Ben and Mika
Ben and Mika
Hi Guys
Here our build update for the 52Fiper
Hope you like our mods
Ben and Mika
Custom build winged tailgate with hidden tool storage we called it the
"52Fiper TOOLGATE "
When open normally works just like a regular tailgate
when hidden latches released outer tailgate part opens and shows tool selection.
(this is just a foam template original will be made of Wild Cherry wood)
Inside of the down part now functions as workbench
Like to hear your opinions ( you can also see our 2.5" dual exhaust in the bed rails)
Cheers Ben and Mika Verduin
More pictures and build you can see at
http://www.americandreamcars.ca/html...t10_viper.html
Ben and Mika
"52Fiper TOOLGATE "
Hi guys , of course the heat of the exhaust was also our first thought and concern. Inside the 3" there is an 2.5 exhaust, the space between is open to forced air when driving over the entire length of the bedrail. If that will still make the bedrail too hot we have a second solution but we have all the trust it will be OK It will get a little warm but not hot. Ben
Latest update 1952 Ford F1 "52Fiper"
We have the brakes all ready to go , all looks nice and clean.
Finally Good brake pedal pressure ( after two flushes we still found still air ?? )
Next step is to work on the body and get the metal all welded and formed so it can be ready for primer.
We are going to use our classic european tool instead of bondo ( ofcourse only were its needed , its a old lead spray tool ( see picture) We use the eastwood lead "free" lead but that does not mean we are using it with very good ventilation and protectection.
We also have some great never been done Paint ideas... Keep you posted
Thanks for watching
Ben and Mika
http://www.americandreamcars.ca/asse...s/108_4650.jpg
15" rotors
Our lead spray tool
Thanks for watching
Ben and Mika
15" rotors
Our lead spray tool
Received 1,353 Likes
on
