Cleaning a bag filter???
Can anyone give me some tips on how to clean a bag filter? I just picked one (100 mic) up for my 275 gallon tote and plan on using them for magnesol filtering. But after about 25 gallons going through it into my tote tank its ready to be cleaned. So any sugestions?
100 micron is kinda small for a one time pass. I would start at 400 then 100 micron. When i was using bag filters that seemed to work for me. It made the smaller micron go a little further. I also used brake cleaner in a spray can to clean the bag. that should work for a wile but can be a pain. Filter bags are meant to be thrown away after full. That can get spendy.
Hey armstrong, is that how you are filtering your raw wvo? or is that how your filtering magnesol? It looks kinda dark?
I use the 100 mic bag filter on my tote tank to pre filter my wvo before I get ready to pump it over to my processor. But the darn thing just plugs up on me. Its a pain to clean the long filter bags when they get loaded with gunk.
Thanks for your help!
If you are using the 100 micron bag filter for your wvo prior to processing into bio, that's overkill. (Unless there's some other reason you are choosing to do this) I use hardware store window screening to filter my wvo prior to processing. It's all you need. Cheap too.
Ok guess I should clarify a bit. I pickup my oil from a couple spots, and its decent but always has stuff floating in it. So as it goes into the storage tote I poured it through a 100 mic bag filter that's about 14 inches long. The raw oil sits in the tote till I need to make a batch.
Then from the storage tote I pump to my processor.
I just got thinking about trying to use magnesol, and everyone on here seems to be filtering the mag in a 3 part filter setup. Everyones mic ratings seem to differ a bit, yet I'm only trying to figure out the proper ways of cleaning a filter bag. Whether its wvo or magnesol on the bag how should they be cleaned? to
